Wiring Diagram Needed
Stratoman78
South Carolina
I'm in need of a complete wiring diagram for my 72 Tele Deluxe Reissue for coils splitter. I have installed two 4 wire humbuckers and cts push pull pots. I want to wire directly to volume pots
With no tone controls. I never use the tone controls. Any help appreciated.
Will_Darden
Oregon, USA
So you basically want the following controls:
- Three way selector switch (bridge, bridge and neck, neck)
- Push/pull pot for neck volume/coil split
- Push/pull pot for bridge volume/coil split
No tone controls whatsoever?
Fralin Pickups has the basic base for the wiring you want. If you don’t want tone controls, just eliminate the tone pots altogether and ground the volume pots to one another, but I would probably leave the tone controls in and just hide them in the body cavity after I adjusted them where I wanted them.
  • Gibson-Hum-Hum-Split.pdf
Tuxedo Poly
Merseyside UK
Something like this should work.
New Posts
