Wiring Cliff output speaker jacks
Discussion in 'Amp Tech Center' started by DucDone, Jul 30, 2021.
  1. DucDone
    DucDone Tele-Meister
    Bergen
    Hi. I am a bit uncertain on the best way to wire three speaker outputs, Cliff jacks instead of the ohm selector. Anyone has a good layout for that?
  2. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    I'm assuming you want a separate jack for each transformer output impedance?
    If so, you don't want the switching to be connected on any of the jacks.
    Bridge all of the grounds together -- the connectors closest to the front of the jack to the common output of the transformer -- then connect each transformer output to the hot of each individual jack.
    Since you can't have switching, make sure there is always a speaker plugged in before turning on the amp.
    King Fan and Peegoo like this.
  3. Paul G.
    Rhode Island
    Not the greatest picture, but here's a sample.
  4. corliss1
    corliss1 Poster Extraordinaire Platinum Supporter
    Lansing, MI
    what @Paul G. posted - tie all the grounds together, and then each output to the hot connector. You're basically just not using any of the switching functions of those style jacks.
    King Fan likes this.
  5. King Fan
    Salt Lake City
    Good info. Is the absence of a switching jack maybe an argument for a selector switch? I see this done with multiple jacks a lot, so that must be a popular solution… but we also see many worried posts by folks who forgot to plug in a speaker.
  6. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. Great Britian.
    Why not fit switch jacks and wire accordingly using a small relay and the heater supply to power it.
    That's what I do.
  7. Bendyha
    Bendyha Friend of Leo's Silver Supporter
    Northern Germany
    Neat! I like it. Thanks Jon.
  8. Bendyha
    Northern Germany
    These are for two optional impedances using switching cliff jacks the way I do it.
  9. schmee
    Just use the switch and the original grounding jack (after the switch) that the amp came with.
    You are now just like original, but with various impedance taps.
