You don't have to do it that way, of course. It's just more tidy, plus it allows the hot and ground solder locations to be further apart.So that there is a ground wire that is easier to solder than the braided wire?
If so, this was already done by Harley Benton/Roswell.
It wouldn’t have occurred to me to do this, but it makes a ton of sense and will use this trick from going forward.
Thanks again for your help with this.
I can’t count the number of times you have made custom diagrams for me.
I would say 90% of the guitars I have built have your wiring in them.
For the braided lead, I like to tease it loose at the end, and twist it into a stubby lead, and shape it into a J hook. Put a similar hook bend on a new length of wire, and join the two. Solder.
Then, bend it back along the body of the original braid lead, and slip a piece of heat shrink tubing over the joint. Nice and neat.
Here's a similar example, though with another type of coax.
Hey @Peegoo, this is great. Do you have one of these for a dpdt toggle? And one for a blade switch? The translation from wiring diagram to guitar seems to confuse many people. I always mention using a meter to 'discover' a switch, but I doubt anyone besides me actually does it.Adding this for more clarity here...this is how the internal switch connections work in a push-pull pot.
Place either probe on a lug you suspect is the common for that pole.
I was about to say, I have never suspected any piles of being common.I always mention using a meter to 'discover' a switch, but I doubt anyone besides me actually does it.
This looks clean! Nice idea.For the braided lead, I like to tease it loose at the end, and twist it into a stubby lead, and shape it into a J hook. Put a similar hook bend on a new length of wire, and join the two. Solder.
