Wiring advice please
Discussion in 'Tele-Technical' started by Robertgoodwin24, Jan 18, 2020.
  1. Robertgoodwin24
    Robertgoodwin24 TDPRI Member
    Norfolk, UK
    I am wiring my first Tele this weekend and I have an issue. The jack input cannot be removed as the screws are rounded off. The wiring is still attached through into the control plate section. My issue is that there seems to be 2 ground wires and one hot wire? I have Red and Bare together and a separate black wire.
    I cant see where they are connected to the jack input as they are tucked inside the body.
    Any help appreciated.
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Actually it's called the output jack.
    No biggie, anyway I believe what you are seeing there is the RED positive wire has the braid on it as that is for the propose of shielding the wire (for noise reduction).
    So that shield is most likely soldered onto a ground point of the jack end.
    So your black and the shield (bare/braid) would have continuity if you checked the two with a ohm meter.
    Put the red onto you vol. pot (output)
  3. LowCaster
    LowCaster Tele-Holic
    Paris, France
    I would like to replace those worn screws. You don’t want to be bothered by a screw for the rest of your life? Use a dremel to make a slot and unscrew them?
  4. Robertgoodwin24
    Norfolk, UK
    Sorry, I've attached a picture of what i'm working with
  5. sjtalon
    POS Guitars likes this.
  6. POS Guitars
    POS Guitars Tele-Meister
    Los Angeles
    Show us how bad the screws are stripped.
  7. sjtalon
    Common for humbucking pickup leads too:
  8. kbold
    Common misnomer.
  9. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Plug a guitar cable into the jack and use an ohm meter to check continuity of the wires to the other end of the guitar cable.
    Or remove the jack plate and verify the soldering is not messed up or a wire is broken at the jack.
  10. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    That extra black wire may be an additional ground added by the previous owner. Can you reach into the output jack channel with a finger and feel where the other end is attached?
    What kind of jack plate is it? Can you remove the jack from the plate and pull the jack out?
