Winter project- danelexplorer!
Discussion in 'Tele Home Depot' started by lancashiremick, Nov 14, 2019.
  1. lancashiremick
    lancashiremick TDPRI Member
    Cheshire, uk
    Many years ago whilst playing bass in our street punk band I bought a korina epiphone "popa chubby" flying v and whilst I loved it in many ways, I just couldn't get on with it , to the extent that I traded it very soon afterwards.....
    With the benefit of hindsight I now realise that I should have bought the v's spikier twin, the korina explorer and since then I've never been in a position financially to purchase a brand new guitar.
    However, I do have a shed full of rudimentary tools, a bunch of oddments of timber and sheet materials and ambition far beyond my skill level !
    In my job I'm used to machining metals to .001" with regularity but timber of all kinds seems to have a mind of its own ..
    Stay tuned here for much hilarity as I turn perfectly good materials into firewood or just maybe a playable instrument.
  2. lancashiremick
    Cheshire, uk
    15737698516004782532270730775615.jpg I hatched my plans by downloading 1:1 pdf of a 1958 explorer from a German luthier website. It took me over a week to figure out how to print this tiled in order to make a paper pattern, so we're not off to the best of starts...
    Ekko, crazydave911 and puddin like this.
  3. lancashiremick
    Cheshire, uk
    15737700188847153196202014782950.jpg Armed with my pattern I bought some 34mm planed timber from the local DIY shed which apparently is spruce. Which is a Christmas tree. Glued it into an approximate explorer shape using gorilla glue which I found to be surprisingly good at its job. I at least tried to keep end grain joints to a minimum and tried to ensure good joints by clamping tight.
    Current state of play is that I've roughly cut it out on the bandsaw at work.
    Ekko, Freekmagnet, Carcinogen and 4 others like this.
  4. Treadplatedual
    Treadplatedual Tele-Holic
    Indianapolis, IN
    Be careful with that gorilla glue - it may not hold together as well as titebond would.
    Otherwise, looking forward to seeing the explorer complete!!
    lancashiremick likes this.
  5. RodeoTex
    Nueces Strip
    Gorilla Glue is not much useful in guitar building in my experience. Cool looking project though
  6. crazydave911
    East Tennessee
    First,welcome to the forum! :) One heck of an idea for your first build and as others have suggested (an others will) I'd stick to original Titebond wood glue.Even if you use the original Masonite for the top and back you'll have much better luck with it,and at least here it's reasonably cheap compared to Gorilla glue.I'll be following ;)
    Dave
    Mr_Q and lancashiremick like this.
  7. lancashiremick
    Cheshire, uk
    Thanks for the advice guys, I've found a supplier of titebond 1 in my town so I'll grab some at weekend. The gorilla glue seems to be doing the job on the framing but I will utilise titebond when I glue to top and back on. I'm confident that will tie everything together rigidly like a composite structure.
    I'm undecided as yet whether to use Masonite, plywood or mdf. I know danelectro used Masonite and that would be more true to traditional construction, however I'm more leaning towards 5mm mahogany plywood.
    I'd quite like to also bind it front and back and do a hand rubbed violin finish which is why I'm thinking plywood. Any thoughts?
  8. epizootics
    epizootics Tele-Meister
    Lyon, France
    There seems to have been a flood of Gorilla Glue products hitting the UK in the last year or so...Their wood glue looks like your typical American-type yellow PVA glue, although I haven't tried it yet.
    The original Gorilla glue might actually make a better job than its PVA counterpart on the end grain joints. It is one of those areas where PVA doesn't perform well.
  9. lancashiremick
    Cheshire, uk
    I "sized" the end grain joints first and theyre holding very well. However I will be using titebond for the remainder of the build...
  10. hopdybob
    hopdybob Tele-Afflicted
    netherlands
    MDF is a nasty kind of 'wood' screw will not hold well, chips very fast and soaks moisture and will swell.
    Masonite is way better, and a solid plywood will hold to, but i think Masonite will be easier to give it a solid color.
    maybe you could go and find some pieces of solid parquet, i have done this with a project of mine as a top.
    seems to me it will be a fun project
    weevilcaster and lancashiremick like this.
  11. matmosphere
    matmosphere Tele-Holic
    earth
    Very cool idea! I built a Dano style guitar a few years back and my vote is for Masonite all the way.
    But with the caveat that it’s probably a little more work to paint than plywood. Less sanding but more priming. I think it’s also much stronger than a piece of plywood that is the same thickness.
    if I had done a little nicer job with some of the woodworking I probably would have just carefully curved the edges with my router and done a clear coat on just the Masonite with the wood frame. It looked very cool that way, but I needed to fix up a little around the neck pocket and string through holes so solid color it had to be.
    crazydave911 and lancashiremick like this.
  12. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    Gorilla Glue is fine for what you did in your second photo. Now up it away and don't use it again. ;)
  13. lancashiremick
    Cheshire, uk
    Gorilla glue is now hidden away in the shed, out of sight out of mind. I'll be using titebond from here on....
    Treadplatedual likes this.
  14. Teletubbie
    Teletubbie TDPRI Member
    North London, UK
    Totally off topic but I'm a regular visitor to Cheshire as my brother [black sheep of the family, he's a bass player] lives in Goostrey.
    Looks like an interesting build, what are you going to do for the neck?
    Cheers.
    Edited 'cos I can't type.
  15. Mr_Q
    Mr_Q Tele-Meister
    Iowa
    Mahogany plywood will require grain filling, and the edges will be really apparent unless your binding covers them. But it'd probably be attractive.
    By violin finish, I guess you're talking about French polish. I think it's a lovely choice, I've never tried it, but a friend tells me it's a lot of work.
    Good luck, I'll be watching your progress!
    Sent from my SM-T810 using Tapatalk
  16. Jmwright777
    Jmwright777 TDPRI Member
    Idaho
    Interesting build, I will be following this!
  17. Jim_in_PA
    Jim_in_PA Tele-Holic Ad Free Member
    SE PA near New Hope PA
    This will be an interesting build...'looking forward to more!
    Polyurethane glue (" Gorilla " is just one brand that has it) has it's purposes, but one has to be careful with it, too. It has zero gap-filling properties...if you see foam "in" the joint, it's not a good joint. Things need to be tight. It's also moisture cured. And lastly, if you get it on your hands, you'll have black patches on your fingers until it wears off. :)
    Regardless of the glue, be careful of end-grain joints. For this build, the caps will deal with keeping things together structurally, so you shouldn't have much issue with the "frame" in the corners, especially that lower horn area, but just the same, whenever you can avoid end-grain to side-grain, that's a good thing.
  18. lancashiremick
    Cheshire, uk
    Thanks for all the interest in the project everyone!
    It may or may not all end up as a total disaster yet but all advice is welcome....
    I'm originally from Lancashire but im a recent emigree to Cheshire and I still travel north for work each day as a jobbing engineer. Which is how I have access to my Bridgeport universal mill and my capstan lathe. And a bandsaw.
    Which is why I'm planning something slightly wacky with the neck....
    brandonh and Steveinthesticks like this.
  19. lancashiremick
    Cheshire, uk
  20. lancashiremick
    Cheshire, uk
    Right o, here goes...
    I'm planning on using a stop tailpiece and tuneomatic bridge like a 'real' explorer. I know that means one way or another I need to angle the neck by 2°.
    The neck came from an auction site for cheaps and is an "encore" brand. Here in the UK, encore is looked down upon as a beginner brand but this neck turns out to be really nice. Fingerboard is proper rosewood, it's arrow straight and the frets are level and nicely rolled. My gigging bass was an "encore coaster" , a precision clone and it was great.
    I'm just gonna blurt it out ha ha!
    I plan to source some maple and add a long tenon and shaped heel then mill a 2° angle and step into it.Then mill the neck pocket parallel and glue it in.
    It's fender scale which throws the drawing off which is why I left so much timber either side of the centre block for bridge placement.
    crazydave911 likes this.
