Winder counter suggestion?
Discussion in 'Tele Home Depot' started by Potatocaster, Jan 13, 2020.
  1. Potatocaster
    Potatocaster TDPRI Member
    Fayetteville, Arkansas
    Hi all, I have a Pennstate Penn Pal lathe I've started using for pickups. I had originally bought materials for a winder counter, but the penpal doesn't work with the instructables machine I bought parts for as the disk for that is too large.
    Anyone have any recommendations for a counter style that can handle 1.5k turns per minute? I'm fairly new to this business. Affordable is nice.
  2. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    I use the counter in the photo.You can find it on AliExpress and eBay also.
  3. kbold
    At that speed electronic would be better than mechanical.
    Proximity switch (picking up counts from a protruding piece of metal) into a digital counter.
    Setup should be easy, and fairly cheap.
    Edit: Someone beat me by a few seconds.
    Potatocaster and nickhofen like this.
  4. nickhofen
    It happens to me all the time!
    :lol:
    Potatocaster and kbold like this.
  5. Fiesta Red
    Fiesta Red Friend of Leo's
    You must have a HUGE house.
    I counted all the winders on my house and only had to take off one shoe!
  6. Jupiter
    Osaka, Japan
    I got basically the same one as nick. I think it's good up to 1200 rpms or something.
    R. Stratenstein and Potatocaster like this.
  7. guitarbuilder
    Potatocaster likes this.
  8. Potatocaster
    Thank you so much everyone! This has been super helpful!
  9. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
  10. Potatocaster
    It's a struggle, but I try to fight the good fight with my legion of counters ;)
    Fiesta Red likes this.
  11. Potatocaster
  12. RickyRicardo
    Calgary, Alberta
    That'll work. I haven't had to go to 10000 on the pickups I've made so far so a 4 digit counter works for me.
  13. Potatocaster
    I'm aiming for lower winds myself as well.
  14. darkforce
    darkforce Tele-Meister
    Germany
    From the description it does not look like it has a count feature (it does count internally, but I think it will just output revolutions per minute).
    For the winder I'm currently building I used an Infineon TLE4905L Hall sensor connected to an Atmel microcontroller. The sensor is connected as an interrupt, so just counting all the leading or trailing edges is all that needs to be done. The count is displayed along all the other info (set number of counts, winding direction, speed etc.) on a small LCD display with HD44780 controller. If you want further information on this design let me know.
    Best regards
    Johannes
  15. RickyRicardo
    Calgary, Alberta
    You're right. I didn't notice. That is a rev counter. The one I posted is a proper counter.
  16. Ronkirn
    Jacksonville, FL
    guys get an optical counter,, a magnetic proximity counter limits the speed of the wind to about 1000 - 1200 rpm. that means the whole process from time ya start feeding the start through the eyelets, get the bobbin mounted.. get the thing would and off and the finish 3rd through the eyelets is gonna be about 15 minutes per pickup..
    With an optical, once you gain a little experience you can wind up to 2500 .. that drops the time significantly...
    the reason is "dwell", the time the magnet is in close enough proximity to the sensor to activate the counter... with the light activated one, it's instant.. not so with the magnet...
    rk
  17. darkforce
    Germany
    If we are talking Hall effect sensors (reed switches are indeed too slow for this application), this should not be a problem. Even 10000rpm with a single magnet is still shy of 170 Hz for the sensor. I think you would be hard pressed to mechanically rotate just the magnet fast enough to see the bandwidth limit of a typical Hall sensor.
    An optical sensor also has limited bandwidth. Granted, that bandwidth can be quite high (easily in the GHz regime for fast detectors), but still limited. For this application it does not matter at all though :lol:.
    Best regards
    Johannes
  18. Potatocaster
    Do you have any suggested models? I've tried to find one, but I'm out of my depth
  19. Ronkirn
    Jacksonville, FL
    Sorry but no.. I built my lathe over 15 years ago... back then I got the counter off eBay... perhaps others that have built winders more recently may have a lead..
    r
  20. Potatocaster
