Will this soldering kit suffice?
Discussion in 'The DIY Tool Shed' started by omlove, Aug 9, 2019.
  1. omlove
    omlove Tele-Meister
    new york
    Got the bug into wiring and started looking online about soldering equipment. Found this kit at $16.99 60W:
    https://www.amazon.com/dp/B06XZ31W3M/
    For a little money there's this at $27.99 60W:
    https://www.amazon.com/dp/B073VDX4B7/
    Then there's the standards Stewmac set at $77.85 40W iron:
    https://www.stewmac.com/Luthier_Tools/StewMac_Tool_Sets/Guitar_Electronics_Tool_Set.html
    ...or deluxe at $209.24
    https://www.stewmac.com/Luthier_Tools/StewMac_Tool_Sets/Guitar_Electronics_Deluxe_Tool_Set.html
    Would the first set suffice? It's so cheap that I'm worried but the reviews seem good.
    I am considering guitar wiring mods, perhaps amp building may need more tools. or not?
    Thanks for your response in advance.
  2. viking
    viking Friend of Leo's
    Denmark
    I havent looked at the links
    For guitar , you need at least 40 w
    Some jobs in amps require more
    Whatever you do , make sure you can get new tips.
  3. hotpot
    hotpot Tele-Afflicted
    Lancashire UK
    I got the first one on your list and it's been fine, I don't do a great deal of soldering and didn't want to spend a lot of money on one. It gets up to temperature quicker than my old one and I've done half a dozen soldering jobs with it no problem at all.
  4. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    I do it all with a cheap 25W iron, 40 would make some jobs easier (soldering back of pots, humbucker cases, etc) but good technique you can solder these solder to the back of pots neatly without damaging them.
    ponce likes this.
  5. Shuster
    Shuster Poster Extraordinaire
    Bulverde Tx.
  6. 6stringcowboy
    6stringcowboy Tele-Afflicted
    Central North Carolina
    Aoyue 469 Variable Power 60 Watt Soldering Station with Removable Tip Design- ESD Safe https://www.amazon.com/dp/B00MCVCHJM/?tag=tdpri-20
  7. bondoman
    bondoman Tele-Meister
    vallejo ca
    I have a few irons but this my favorite and probably my cheapest. Down side is it didn't come with extra tips but those are cheap sold separately. [​IMG]
  8. Commodore 64
    Commodore 64 Friend of Leo's
    Kent, OH
    I use a Weller WES51. I think this is the current: https://www.amazon.com/dp/B077JDGY1J/?tag=tdpri-20
    Started with a 20 cheapy station. Then a $50 35W weller pencil which I used until the bushing holding the tip on disintegrated (from use, I made several amps with it). Then I finally got the WES51. Shoulda done that a long time ago.
    Spend the money now if you plan to build amps. You wont regret it. And get a decent autoranging multimeter.
    Andy B likes this.
  9. JuneauMike
    JuneauMike Friend of Leo's
    Alaska
    WTH? That's not a soldering iron, it's a robot.
  10. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Get the Harbor Freight $7 "25w" iron, solder, and a bit of sandpaper, and a $2 solder sucker off Amazon. You'll have all you need. Sure you can go all robot fancy "I need a Custom Shop guitar to sound good" approach but soldering is technique. You can build a nice stand from a coat hanger bent in a spiral screwed to a scrap of wood.
    Solder backs of pots: sand paper a little circle spot, heat the spot with the iron and feed solder at the interface of the iron and pot. The solder transfers the heat. Heat the stripped end of the wire(s) and flow solder into the wire(s). Now press the wires to the pot, held down with the iron, and feed in a little more solder. Put the solder down and grab a wood chopstick/pencil/twig from the yard to hold the wires in place while you pull the iron away and let it all cool down. You want smooth and slightly shiny cooled solder when done that looks like the sides of Mt Fuji. If slushy, grainy, dull, or a blob then reheat and remove or add some solder as you need. Solder sucker is for removing most of the solder at a joint to do a repair.
    yellowbeard, Splodgeness and jimbo735 like this.
  11. Milspec
    Milspec Friend of Leo's Silver Supporter
    Nebraska
    The advice I give is to get an old Weller analog station. They did the job for decades and a good one is still as good as anything out there. I started using the Hakko station 3 years ago and it is a good unit as well, but those old Wellers just seem to have more horsepower and just work well. Used, maybe $40 or so for a clean one.
    SacDAve likes this.
  12. schmee
    I like 40 watts, it will do most everything. Don't go for gimmicks or self soldering junk.
    Make sure replacement tips are available for the one you buy and not overpriced!
    After a couple decades of soldering I got an adjustable one. Guess what? I leave it wide open anyway! Waste of money for me.
    Also get a solder sucker of some sort.
  13. yellowbeard
    yellowbeard Tele-Holic
    florida
    ^^^^^^ This....and I would add make sure to use a 60/40 resin core solder. The rohs compliant stuff is a bugger it needs a lot of heat to melt and flow. Keep your tip clean and tinned, after use clean and tin it before you put it away.....and don't breathe the fumes they'll make you null and void.
  14. SacDAve
    SacDAve Poster Extraordinaire Silver Supporter
    Rocklin Ca.
    I bought a nice Weller station I don't regret it one bit (WES51) great for amp builds. Multi meter after my $50 craftsman meter blew up I bought a fluke over $100 but but all kinds of safety factors built int Flukes truly proffesional tools.
    Milspec likes this.
  15. alathIN
    alathIN Tele-Holic
    Indiana
  16. bumnote
    bumnote Tele-Meister Ad Free Member
    Northern Virginia
    Just starting? The second kit from Amazon will start you off fine. I have a couple of similar irons like that. They work fine...but the temperature dial isn't what I'd call exact.
    First time out, buy extra pots and caps...you bound to burn a few up.
    These are a good cheat that I've used in the past instead ground each pickup to a pot...
    Allparts EP-4968-000 Solder Lug washers https://www.amazon.com/dp/B00GIU6IY8/?tag=tdpri-20
    If you like it...then look into more expensive and elaborate setups. Why spend a lot of money up front for something you might not decide to continue on with.
  17. kbold
    Like a lot of purchase situations, you start off with the cheapest, which soon does not cover your needs. Then you buy medium range, and later you buy a proper soldering station.
    If your occasionally doing itsy-bitsy stuff, go cheap - it will get the job done.
    If you are soldering regularly, buy a proper work station from the start. Your soldering will be better, and you won't have spent extra money going through the improvement chain.
    Same goes for multimeters, side cutters etc etc.
    Milspec likes this.
  18. strat56
    strat56 Tele-Holic Silver Supporter
    Elkton,MD
    I bought one of these, Weller WESD51, in 2011 and it has worked flawlessly for 8 years. Heats up quick, recovers quickly and maintains the temperature. Many of the less expensive irons don't recover quickly and don't maintain a consistent temperature.
    https://www.amazon.com/dp/B000ARU9PO/?tag=tdpri-20
    Milspec likes this.
  19. TimTam
    TimTam Tele-Holic
    Melbourne
    To answer your actual question, yes, the cheap first kit will be fine.
    There are very decent cheap irons around now. I used an expensive Weller WES51 for several decades. When it eventually died I went for something cheap with good reviews, very like your link - 60w, temperature adjustable. As you've found, for less than $20 you now get one with a whole kit of important extras that you used to have to buy separately ... extra tip shapes, stand with sponge, sucker, solder, tools.
    It used to be that cheap irons weren't that great but often 'did the job' if you weren't too fussy. Now cheap irons are actually pretty decent.
    If you don't have a multimeter, get the Amazon kit you linked that's bundled with one. It's got most of what's in the Stewmac kit, for 1/10 the price.
    The only other thing you really need is a 'third hand' .. eg
    https://www.amazon.com/dp/B0002LLWYK/?tag=tdpri-20
    The magnifying glass is not that useful if your close sight is OK. If it's borderline, consider an illuminated desk magnifier.
  20. KG7IL
    KG7IL TDPRI Member
    Eatonville, WA edge of cowtown
    I purchased this unit on Amazon
    75 watts with adjustable temperature. I also bought extra tips at the same time.
    It is very convenient to use.. and to quickly disassemble and put back in the box for storage. Add some 60/40 tin lead solder and some decent paste.
    I've been soldering since the early 60's and this is very nice for the price.
    It can handle most of your delicate board work to the back of pots.
    https://www.amazon.com/gp/product/B01DGZFSNE/?tag=tdpri-20
