That's the Beech there, with an Ash cap. the picture makes the Ash look darker than it actually is.Beech?
I would, if I had enough genuine mahogany for a body, but I guess I'm i a thrifty mood and I'm kind of using of a lot of spare bits and pieces left over from unused parts and/or stuff I bought and never used. I'm actually considering throwing my two epi dot humbuckers in there. If I do that though, I will remove the high frequency choking covers. Apparently they have quite a negative impact on their tone. I'm thinking of putting the neck pup in the middle position and the bridge pup in the bridge position. I have a GFS hight output tele neck pup that I'm thinking of putting in the neck position.If it was mine, I’d build it without the mahogany. Could be perfect that way.
I have pretty definite definition of what I consider a "hollow body" as well as a "semi hollow body" - both have some wood structure in the center of the body to support pickups and the bridge. I usually use spruce or maple but there is absolutely not reason those could be mahogany, in fact mahogany makes very good brace wood and is sometimes used in acoustics. Does the wood choice have an effect on the sound? I believe that every choice you make has some effect but probably not that you will hear it or it will matter.The general consensus would suggest that I'm a raving misguided tone lune (on this specific matter), but I'll prove you all wrong... when my guitar is the bestest mahoganyest toniest axe ever! or maybe not.
Just to be clear though, when I said hollow body, I guess that wasn't fully correct, in that I will most likely retain the Beech wood down the center of the body, but stopping short of the base of the body. I aim to just retain a center core of Beech to support the bridge, tail piece and pickups to be screwed into; so there'll be kinda like a hollowed out U in the body.
In fact, I might just drill a load of large holes in that U shape. Still undecided. I think if I was to go fully hollow, BUT glue a solid mahogany block under the bridge that was also glued to the bottom of the guitar, that would probably reduce feedback, like @Telenator mentioned above, but I don't think I'll be going fully hollow.
In any case, yeah, I agree, the final sound I will get will be whatever it will be, due to a crap load of factors and is impossible to predict to any reasonable degree of accuracy. That said, no harm in giving my cherished blocks of mahogany a new home.
Interesting rabbit hole that guy is tumbling down. I just hope he doesn't go too deep, for his own sake.It won't make any difference.
Without trying to start another tone-wood discussion, watch this video and make up your own mind.
(1) Tested: Where Does The Tone Come From In An Electric Guitar? - YouTube
Very nice! Yeah, I tend to agree with what you consider hollow and semi hollow. Currently I'm just trying new things on each new build I undertake. This will only be my ninth build, so I'm learning all the time and also trying things out design/construction wise, within the confines of reason of course. I do agree that every part of the guitar of the guitar has SOME effect on the it's final sound. I guess it's a bit like making a stew; you throw in whatever you think will help achieve the taste you're after, but the more the components, the harder it becomes to decipher what component attributed what part of the sound and how much; and then there's the amp and speaker of course...I have pretty definite definition of what I consider a "hollow body" as well as a "semi hollow body" - both have some wood structure in the center of the body to support pickups and the bridge. I usually use spruce or maple but there is absolutely not reason those could be mahogany, in fact mahogany makes very good brace wood and is sometimes used in acoustics. Does the wood choice have an effect on the sound? I believe that every choice you make has some effect but probably not that you will hear it or it will matter.
Pictures attached of the bracing on a hollow and a semi hollow body
I'm a beech fanYeah,
Yep, Beech.
My most recent hollow body guitar was Beech too (wish an Ash cap). Turned out really nice. I got a massive slab of it at my local lumber supplier, so this is the last Piece of it that I have.
This might actually be helpful if you were talking about the same thing the rest of us are talking about.It won't make any difference.
That would certainly prevent the soundboard from making any unwanted (or wanted) sounds.I think if I was to go fully hollow, BUT glue a solid mahogany block under the bridge that was also glued to the bottom of the guitar, that would probably reduce feedback
You had me at “mahoganyest.”The general consensus would suggest that I'm a raving misguided tone lune (on this specific matter), but I'll prove you all wrong... when my guitar is the bestest mahoganyest toniest axe ever! or maybe not.
That's the last video I'd watch on that subject. He should stick to playing.It won't make any difference.
thanks. I'm tempted; I really am.I say try it.
There’s an element of unpredictability with all of them. People often talk about two different solid body guitars they tried at at shop. Same make, same specs, same year, same woods. One winds up feeling more resonant than the other for whomever is trying them out.
Ultimately you’ll know you did something unique. And if you like the results, well all the better.
That beech guitar is gorgeous.
Unfortunately I'd say there's not enough to do that. Some of those pics probably make the pieces look bigger than they actually are, but no biggy.It looks like there might be enough mahogany to fashion a center piece and then add Beech wings, like a three piece body.
Thank you for the new vocabulary. I love it...also very light, but stiff, like unkaputtbar.
