Will a plastic nut rob tone?
Discussion in 'Tele Home Depot' started by paulskirocks, May 5, 2010.
  1. paulskirocks
    paulskirocks Tele-Holic
    Norcal
    I have a Yamaha neck that I am using for a build, and it has a plastic nut (Les Paul style at the end of the fretboard, not notched)...
    So, I am wondering if replacing the nut with bone or graphite will really matter, or if it works, don't fix it... If it makes a difference, this guitar will have a tremolo...
    Thanks again
  2. BritishBluesBoy
    BritishBluesBoy Former Member
    Brooklyn, NY
    I guess it depends on what kind of plastic it is.
  3. TNO
    TNO Friend of Leo's
    NC-USA
    Yamaha used pretty cheap plastic in the early days but if it dates to newer than the early 80s I wouldn't bother replacing the nut.
  4. ordenes10
    ordenes10 Tele-Meister
    germany
    old Gibson ( 50 LP) has plastic nuts and they are sounding good
  5. Al Watsky
    Al Watsky Tele-Afflicted
    New Jersey
    Composite materials sound "different" than bone.
    If its cut right its OK.
    If you don't have specific reason to change the nut don't.
    Bone will sound brighter and is preferred on acoustics.
    Electric players that play in the open and first position a lot will also appreciate the subtle difference.
  6. iansmitchell
    iansmitchell Tele-Afflicted
    Gainesville, Florida
    Nylon, actually.
    Saddles, too.
  7. Mojotron
    Mojotron Poster Extraordinaire
    Seattle
    As long as it's set up correctly, it's only going to make a difference for the open notes (non-fretted). So, it kind of depends on your playing style. Also, your gear is going to make a difference too - lots of effects/overdrive/compression or a multi-effect box will make the nut material immaterial.
  8. Guitarnut
    Guitarnut Friend of Leo's
    From projects with one of our biggest clients, I've learned that Nylon, or Fiber66 as DuPont code named it in the beginning, is a synthetic polymer and is classified as a plastic...so you're both correct. :D
    Peace,
    Mark
  9. Colt W. Knight
    Garland, Maine
    IVe played plenty of synthetic nutted guitars that sound fine.
    For the record, I like bone, but I don't think its an end all - beat all nut material.
  10. Guitarnut
    Anything you do to an instrument makes a difference. The key is, will you be able to hear it. Use the old nut as a guide for making a couple others out of bone, brass, Tusq, whatever, or buy some ready-made. See if you like one better than the other...worst case, you can put the original back on and have a stockpile for future projects.
    Peace,
    Mark
  11. Nick JD
    Queensland, Australia
    I have a 12 string with a plexiglass nut and saddle - sounds awesome.
  12. Zatar
    Zatar Tele-Meister
    Hamme - Belgium
    Why not just try? If it works then that's a good thing, if it doesn't you at least got the experience :)
    In my opinion it looks better when it's bone instead of plastic but that's a matter of taste i guess
