Wilkinson Vintage-style bridges - Differences
Discussion in 'Tele-Technical' started by backwater, Feb 24, 2021.
  1. backwater
    backwater TDPRI Member
    Edinburgh, Scotland
    Hi Folks,
    Looking for a vintage style bridge for my current build and I was looking at Wilkinson bridges but I'm curious/confused by the different models/markings.
    I've seen them marked Wilkinson, Wilkinson M Series, Wilkinson by Sung Il and Wilkinson by Gotoh. The Gotoh one is obviously made by Gotoh (and priced accordingly) but does anyone know the difference between the other 3 versions?
    Thanks
    Andy
    LutherBurger likes this.
  2. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    Interesting. I was only aware of the Gotoh and Sung-Il versions.
    I wonder whether the other two are legit.
    That Cal Webway likes this.
  3. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    Maybe M series is metric hardware? Just go Sung Ill, they are perfect
    nojazzhere likes this.
  4. LutherBurger
    NYC
    That's a reasonable guess, but everything about my Sung-Ils appears to be metric: M3 saddle screws and M4 pickup mounting holes.
  5. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    The couple I have were all metric. As an experiment, I tapped the intonation and saddle height threads to 6/32:
  6. backwater
    Edinburgh, Scotland
    I've done a bit more digging.
    The Wilkinson branded one is sold by Allparts as TB-5129-001 :
    Wilkinson® Vintage Style Steel Bridge for Telecaster®, Staggered Saddles, Nickel, 2-1/8" (54mm) String Spacing. Works as a both a top loading and string through body, bridge
    The Sung Il one is listed as model WTB : Chrome finish,stamped steel, Compensated brass saddles - seems to be the most common version.
    M series are models WOT01 and WOT01T :Cold roll steel base plate, angled brass or angled threaded steel saddles (From : http://www.guitar-parts-depot.com/start-tele-style-bridges.html - only place I can find that sells them other than ebay?)
    Andy
  7. The Ballzz
    The Ballzz Tele-Afflicted
    Las Vegas, NV
    Notice the different saddles on the "M" series!
    Just Noticin'
    Gene
  8. yegbert
    Maryland (US)
    I have yet to see threaded steel saddles that have been made compensated by drilling for their intonation adjustment screws in an intentionally angled way (other than perpendicular to the saddle) to provide compensation. The ones listed under those part numbers on that link/page, both brass and threaded steel, look like they were drilled perpendicular. They are and are not compensated, nor are they claimed to be. Anyone have pic of angle-compensated threaded steel saddles?
    That page also lists “Start” saddles! ;)
  9. LutherBurger
    NYC
  10. hemingway
    London, UK
    They all look like big lumps of bridgey metal to me.
  11. radiocaster
    europe
    Top 2 look chrome, bottom looks nickel.
  12. gsh1968
    gsh1968 Tele-Holic
    London UK
    M series are by a manufacturer who claims to have a license to use the Wilkinson brand name.
    On their aliexpress listings they show a scan of the supposed license/authorisation letter.
    I ordered one of the hardtail bridges to check it out and it is awful. Badly plated and the mount holes match no standard pattern I've ever seen. The saddle intonation screws sit very high, almost lifting the saddles off the plate. This is Squier Bullet quality and look to me to just be cheap no-name parts with a laser Wilkinson logo. Not the quality I expect from Wilkinson branded parts.
    Based on the above I'd stay away from the M series. The Sung Il bridges are a known quantity with known quality for a reasonable price.
    backwater and LutherBurger like this.
  13. gsh1968
    gsh1968 Tele-Holic
    London UK
    LutherBurger and That Cal Webway like this.
  14. Tuxedo Poly
    Tuxedo Poly Friend of Leo's
    Merseyside UK
    That seems to have expired.
    The details are correct though. Another Trev Wilkinson business called "Whamster" has the same address.
  15. yegbert
    Maryland (US)
    I don’t know if these are made or designed by Wilkinson; I bought them online from a site calling itself RS Guitarworks. They are what I have that uses the same design as attributed to Wilkinson. I have a couple of sets like these, in steel. I guess I actually don’t have any in brass. These had, when I took this pic, metric threaded screws in both the intonation and height screws. One set I later tapped to use US 6/32 in all holes, and now has slotted set screws.
    I also have at least one bridgeplate that has the Wilkinson name on it.
    Some of the bridgeplates I see on eBay, and a couple I have, have string-through holes that are a little higher than ideal and are visibly uneven in height from the plate bottom. Some are dual load and some are only drilled for string through. I have drilled one or two for top load, and it can be a challenge getting the holes exactly where you want them. I used a center punch before drilling but the bit can ten to wander. I also therefore started the holes smaller than the desired target so I could then use a needle file to adjust the final position. It’s not noticeable when the strings are loaded because the ball ends of the strings hide them somewhat.
    https://www.tdpri.com/media/squier-tele-with-vintage-bridge.1710/full
