Verzila
What is the difference in sound between a regular Gib-type humbucker and a Fender-type wide range humbucker? Specifically, in the neck position?
Many thanks
Many thanks
I have a Classic Vibe Squier Thinline with Wide Range humbuckers and a Les Paul with Seth Lovers. The WR sound more Fenderish in terms of attack and tone... they are brighter, but how much of that is due to the pickup and how much is due to the differences in the guitars, I don't know. The Seth Lovers would sound different... probably more Fenderish, in the tele than they do in the LP. You have different woods, different scale which means different string tension, and different construction, so not an apples-apples comparison.
The Wide Range humbuckers I have of course are the reissues. As far as I know, they are the same pickups Fender uses in their MIM teles as well. I don't know how the originals with the CuNiFe magnets would compare. The reissues are really a standard humbucker design made to look like the originals, and I suspect that in an apples-apples comparison they wouldn't sound that much different than other low-output humbuckers. I happen to like them.
I’ve sorta A/B’d these pickups in two guitars I had a while ago. G&L used Seth Lover HBs in their US Bluesboys and many early Tribute (Indonesian-made) Bluesboys. Compared to a Fender (California Series) Fat Tele with WRHB, the Bluesboy was hotter and brighter than the Tele.
Since Seth Lover designed both the PAF for Gibson and the Fender Wide Range Humbucker I have to assume they have a lot in common.
