Why would a pedal suddenly not like to be daisy-chained???
Discussion in 'The Stomp Box' started by E5RSY, Sep 21, 2019.
  1. E5RSY
    E5RSY Poster Extraordinaire
    Georgetown, TX
    After years of good use, out of the blue...makes all kinds of low volume crazy noise when not engaged (ticking, whooshing...it's a chorus pedal) unless it's on battery or isolated. :confused:
    Thanks for any insight.
    Scott
  2. Iago
    Iago Friend of Leo's
    Brazil
    What pedals are in the signal chain besides the chorus? Any new additions?
  3. artdecade
    artdecade Poster Extraordinaire
    Twangsylvania
    Ego?
  4. E5RSY
    Georgetown, TX
    Doesn't matter: In chain or solo, samey same.
  5. 24 track
    kamloops bc
    are the pots dirty? corrosion/ oxydization can cause this anaomally,
  6. E5RSY
    Georgetown, TX
    Maybe. I will give them a good dousing. But, they're not currently scratchy.
    The 20-year-old patient:
  7. 24 track
    kamloops bc
    also may be clean the contacts of the power input as well and supply as well
    I have 3 pedals that sound great on their own wallwart but noisey up to unusable if I put them on a multi power block , it could be a current draw thing , I dont know , as a course of action check the power supply or wallwart to see if it is an issue , what about the battery , does it do the same thing with a battery?
  8. tubejockey
    tubejockey Tele-Meister
    the bozone
    Does it have power supply bypass caps? Are they leaking?
  9. E5RSY
    Georgetown, TX
    Don't know. That's a bit above my paygrade.
    But, if they were, wouldn't the problem exist both if the pedal was being run in a chain or isolated? Currently, the problem only exists when daisy-chained, fine when isolated.
  10. tubejockey
    the bozone
    If your power supply has good filtering, you probably won't notice any difference. The pedals filter should take care of it, so long as it is working.
    Sometimes chorus pedals start to tick when they get old due to poor internal filtering of the clock.
  11. E5RSY
    Georgetown, TX
    Thanks. Don't know if it sheds any light, or not, but the the noises change when the SPEED knob is turned, even when the effect is not engaged.
    Maybe it's just time to put this one out to pasture.
  12. dlew919
    dlew919 Poster Extraordinaire
    Sydney
    What about the wall socket? Could there be an issue there?
  13. E5RSY
    Georgetown, TX
    Maybe, but the power is pretty clean here. And, it used to be fine on the same outlet (I have also confirmed that it is wired correctly).
    dlew919 likes this.
  14. tubejockey
    the bozone
    Sounds like the clock filter. A good tech can fix that.
  15. Guitarteach
    Tried swapping the power supply or using battery?
    Eliminate/swap each bit
  16. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    I would first be suspicious of a ground connection, then maybe a bad pot or switch, after that maybe a cap headed to that big components warehouse in the sky.
  17. Iago
    Brazil
    Yeah, something wrong with the power supply plug on the pedal.
  18. vanr
    vanr Tele-Afflicted
    AZ
    Is there a 20 year old battery still in there and you've been running it on a wall wart for 20 years?
    E5RSY likes this.
  19. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    It sounds like the bypass switching in this series of pedals (which would include the Vibratrem and Guv'nor 2) was prone to issues, and no, they don't have true bypass.
    So my best guess is that something has malfunctioned within the electronic switching itself, and when the pedal shares power with others, it's screwing up the switching so that it doesn't completely fully bypass. It uses a CD4066 CMOS switching chip that has four electronic switches in conjunction with the mechanical DPDT (basically two switches in one) switch.
    The pedals haven't changed, but what about your power supply?
  20. E5RSY
    Georgetown, TX
    It hasn't changed. It's still the same supply that came with the BOSS board.
    I'm starting to suspect it's my house. I played away from the house last weekend but only had it going on isolated power. Forgot to try it daisy chained while I was out. :confused: Need to remember to do that next time, I guess.
    dlew919 likes this.
