backalleyblues
Having played a ton of 335s and Lester’s over the years, along with full hollows and teles, strats etc-EVERYTHING affects the tone of the instrument, down to how you wrap the strings around the stop tailpiece (very subtle, but it’s there)
First off, the attack-the more anchored the bridge and tailpiece, the more focused the attack sound is. To my ears, it sounds like a “D” when the strings are fresh, and goes to a “B” when the strings are dead. With a fully hollow arch top, the attack sounds like a “K”, because of the top and the floating bridge. 335s are in between (as designed) and sound different depending on if it’s a stop tailpiece or a trapeze, with the trapeze leaning towards a full hollow, based on my experience.
The mass of the body has a bunch to do with the tone of course-I have a Lester and an SG (same year) with identical pickups (490s) and they sound radically different, Lester bassier and fuller and the SG more mids and snarl, even on the bridge pickup which is pretty much identical in placement.
The semi-hollow I have (Guild Starfire IV) has a lot less mass to its body (spruce block which is lighter), but is VERY resonant, and I know the body is contributing a bunch of overtones to the sound-it’s quite a bit richer than my Lester or SG.
If you don’t think the semi hollow body has no effect, tap on the body while it’s plugged in, and listen to it, then do the same with a Les Paul or tele, or what have you-my Starfire is quite a bit louder than my Gibbys or Fenders. It’s not as obvious as an acoustic of course, but it’s there (and with heavy distortion, not at all)
As others have mentioned, 335s feel different too-not just the body shape, but how the string reacts to your picking, a slower, rounder attack is what I hear, maybe 2 milliseconds wider than a full solid body.
YMMV…
YMMV…
