Why stick with 3 saddles ?
Discussion in 'Telecaster Discussion Forum' started by TC 57, Apr 18, 2021.
  1. boris bubbanov
    New Orleans, LA + in the
    The load provided by the tensioned string is heavily offset, and often there's not enough pressure to freeze the "offside" height screw in place and it gets to moving around and pretty soon some saddles are being held in place, mostly by the neighboring saddle. As one plays, the tension changes and given enough enthusiastic play, parts start coming off and hitting it stage floor. When I see strings hung up on a "six hammer saddle" bridge, sometimes they're barely restraining a piece of hardware. I've often suggested that to use this "six hammer saddle" bridge, you have to have your tech standing by for most of the show, prepared to hand you a backup guitar once something's gone far enough off the tracks.
  2. blue metalflake
    blue metalflake Doctor of Teleocity
    ireland
    I have 2 Teles, both with three saddle set up. I get very close to perfect intonation without compensated saddles - well beyond what my ear can detect.
    I don’t plan to change anything.
  3. TC 57
    TC 57 Tele-Meister
    England
    This is my Tele bridge...tuned to the 9th degree! it's being able to raise individual strings..but not everyone agrees.. strings are 9-42
    yegbert likes this.
  4. TC 57
    TC 57 Tele-Meister
    England
    if you look at mine...strings never move.. could do with being a bit beefier..
  5. TC 57
    TC 57 Tele-Meister
    England
  6. Jim622
    Jim622 Friend of Leo's Silver Supporter
    Philly
    You don't have a problem with the saddles separating and buzzing?
    nojazzhere likes this.
  7. eddiewagner
    eddiewagner Poster Extraordinaire
    ROCK!linghausen/germany
    3 is cooler
    TokyoPortrait likes this.
  8. nojazzhere
    Foat Wuth, Texas
    @TC 57 .....I'm having a little trouble following your replies to my posts. If your last one said the Thorn Brass Knuckle (one piece) saddle would not conform to the fingerboard radius.....it actually does. You order the Thorn by your specific radius. They make several different ones. In my case, my Warmoth neck is a compound radius, 10"-16", so I ordered the saddle for 10" radius. Works jus fine. ;)
  9. boris bubbanov
    Yeah, I have noticed that the 6 hammer saddle, does all right with 11s, 12s and so forth for some folks, assuming the guitar is not then detuned. I think part of the misadventure was, the 6 hammer saddle bridge is associated with the great James Burton, and he was a pioneer in using thin strings. My sense is, he got away with it because his touch was never harder than it needed to be. This is an extension of the old saw about 'So and So did this and it worked for him'. Really gifted folks have a way of walking on water, when most of us cannot and so they're not always IMO the best template. :^)
  10. TC 57
    TC 57 Tele-Meister
    England
    depending on your set up, if they are set too low, the strings may shift, but , set at right height, and making sure all 12 grub screws butt against the plate top, then I've not had buzzing. I had to modify mine as you can see and replace springs with nuts. The ideal would be Strat style saddles in ashtray plate..but I don't think I've seen one yet...
  11. telemystix
    telemystix Tele-Meister Silver Supporter
    austin,tx.
    These kinds of questions - ALWAYS - provide ME - with a reason to give my "standard" answer:
    I can suck just as badly with six saddles as I do with 3 saddles!
    I choose the 3 saddle suckage, thank you very much!
    JIMMY JAZZMAN and MickM like this.
  12. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    Just here to stir the pot a bit...
    Mastery 2 saddle bridge
  13. Cosmic Cowboy
    Cosmic Cowboy Tele-Meister
    New Mexico
    When Leo got to Music Man and later G&L, he developed several 6 saddle tele models, recognizing the whole situation. The traditional bridge does seem to have a little more spank though.
    Mowgli likes this.
  14. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    When the modern 6 shooter teles were made with their long block shaped saddles, they made the saddles longer apparently to avoid interference with intonation screws; and those longer saddles don’t have enough room on most bridge plates of design as short as true vintage ones.
    But I put the block center-screwed saddles on a Joe Barden plate that was made as a hybrid vintage/AmStd plate; and I think you could also on the similar newer Kluson hybrid, and with Strat style saddles on either (longer Joe Barden or Kluson hybrid).
  15. yegbert
    Maryland (US)
    TC 57, here it is!
    nojazzhere and northernguitar like this.
  16. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    I didn’t read much of this thread, but I’ll say that I like solid bar bridges in many situations. That’s a whole thing unto itself. The 3-saddle Tele is taking a bite into that, intended or not, as is the Mastery or Fender RSD offset bridge. I saw a single saddle cyclops Tele on this forum once, same train of thought.
    Bar bridges make sense on a hollowbody, but only that it increases sustain and kills buzz. It takes away from the thunk and quick decay of a real hollowbody. How about a well-made Melita with Micarta saddles? :D On a Tele, is that really necessary? Nah. 6, 3, whatever. I keep 3 because it’s the way the Tele was made, so I’m traditional in that sense. “Perfect” intonation is a pipe dream anyways, and it’s not going to matter when I bash some chords out :)
  17. Willy-son
    Willy-son Tele-Meister
    NJ USA
    Because they are rock solid, intonate perfectly and I rarely go out of tune. Why these threaded gems didn’t come stock on my American Original 60s is a mystery to me.
    northernguitar likes this.
  18. EspyHop
    EspyHop Tele-Holic
    Dayton, OH
    For me, whether it has three or six saddles is less important than the saddles being brass. That said, I tend to go with three saddles.
  19. DHart
    DHart Poster Extraordinaire Gold Supporter
    Scottsdale, AZ USA
    I like the six saddle option over than the vintage. Either can get the job done, though.
    I'm not attached to anything on a guitar having to be "correct" in some specific historical manner, I just want to like what I see, feel, and what I hear.
  20. Mur
    Mur Tele-Afflicted
    Been setting intonation for decades. Adjustment on every string, on some instruments, is nice. But for me, not on Tele or P-bass. I totally dig those original bridge designs. Its part of the outcome and vibe.
    Willy-son likes this.
