Why no 2 speaker cabs with a 10 and 12?
Discussion in 'Amp Central Station' started by boodle, Nov 2, 2010.
  1. Telenator
    Vermont
    All bets are off until you play it in the context of a band. (if that's how you usually play)
    There is some knowledge to be gained by listening to an amp solo, but if you play in a band, that context is completely different and none of the comparisons done in solo mode will apply.
    It becomes a matter of how well the amp plays in the sonic chaos of a band, and less about the solo tone.
    I learned this from trying to get several of those "do it all" digital multi-effects units to work properly. I would sit at home for hours and dial in tones to die for. Then I'd bring the unit to rehearsal and it always sounded like dogmeat. Didn't work in the studio either. Once it was added to the mix, the sound would fall apart because it was created to be at it's best in silence. The speaker testing, and effects testing really needs to be done in context to get meaningful results.
  2. Tomm Williams
    Tomm Williams Tele-Holic
    image.jpeg J Design built me a cab with a G10m and a G12h and it sounds great. It's the center cab in this photo and was built as a Hofner reproduction. (Aesthetically anyway)
    knockeduptele likes this.
  3. Pluckit
    Pluckit TDPRI Member
    San Francisco , CA
