Why need to separate cathode for RobRob's cascade switch mod?
Discussion in 'Shock Brother's DIY Amps' started by itsGiusto, Aug 20, 2019.
  1. itsGiusto
    itsGiusto Tele-Meister
    Massachusetts
    For RobRob's cascade switch mod:
    https://robrobinette.com/5e3_Modifications.htm#High_Gain_Channel
    He says a few times something like:
    "V1A and B's cathodes must be separated by installing a 1.5k ohm (1/2watt or higher) cathode resistor and one or two 22µF 25v cathode resistor bypass capacitors on V1A and V1B's cathodes (pins 3 & 8)."
    Why must the cathode be separated for this mod? Would it work if you kept the cathode bypass shared, or does it cause some kinda phase cancellation?
  2. corliss1
    Lansing, MI
    Hmmmmmmm...that's a good question. Maybe there are phasing issues?
  3. itsGiusto
    Massachusetts
  4. robrob
    United States
    A common cathode resistor for two gain stages in series can cause interaction and oscillation. My "must be separated" statement is a little strong though.
    King Fan, sds1, Paul G. and 2 others like this.
  5. shortcircuit
    shortcircuit Tele-Meister
    North Carolina
    A while back, I tried to cascade the two triodes in the 6J6 tube with a common cathode resistor, and that thing squealed like a stuck pig. Learned my lesson.
    King Fan and Paul G. like this.
  6. itsGiusto
    Massachusetts
    Cool, thanks for the clarification! So if I want to avoid higher chance of oscillation, I should separate then.
    When you separate the cathode, but want to keep the same exact bias and tone, you should use two resistors of double the value, right? And use the same value cap?
  7. corliss1
    Lansing, MI
    Correct - since the cathodes are no longer in parallel you'd double the resistor value.
    King Fan and robrob like this.
  8. dan40
    dan40 Tele-Afflicted
    Richmond Va
