Three Eyed Willy
I'm finding that my guitars are commonly a tiny bit sharp when I start. The "sharpness" is usually fairly consistent - as in, it is reasonably in tune with itself, just sharp. Every once in a while, but far less commonly, a guitar will be a bit flat. My house is pretty well climate controlled - consistent temperature between 70 and 75, and I keep a humidity meter in the room (always between about 42 and 65%). I keep all my guitars on a typical guitar stand. Just curious what makes a guitar go sharp...flat, I understand.
My first question is what you are using as a tuning reference? Are you using a Snark? A Peterson product? The level of quality varies from one brand to another.
Second, how do you judge your intonation? Comparing 12th fret harmonics to 12th fret note is usually pretty good, but you will be listening to sequential notes. It's much easier to calculate correct tuning if you can hear both tones simultaneously. Reading the intonation from a good tuner is probably as good a way as any.
