Brent Hutto
Here's a snapshot of three pedals I have engaged (along with my usual delay) at the moment. All of them are turned way down in terms of Gain on the dirt pedals and Sensitivity (pretty much all the way down) on the Dyna Comp. So they add a little grind to chords and maybe a slight edge to single notes if I dig in a little. But really not distorted or compressed sounding at all.
It's playing through the Clean channel of my Katana with its (clean) Gain pretty high and a fairly neutral EQ.
Here's my question, what is about this combination of pedals that make the highest notes on my Telecaster (above the 12th fret on the high-E string) sound fatter, thicker, more sustaining, just all around much better than if I turn the pedals off?
If I run just one or two of the pedals rather than all three I don't really hear a major difference from the tone of the amp only. But with all three running, even turned down so low, all of my usual thin, plinky high-note sound is gone. It's like turning on a feel-good pump for my trebles.
P.S. And BTW, it's not just louder. If I adjust the volumes to be almost exactly (within 1dB) matched the tone with the pedals on is still far nicer.
