timeconsumer
Do you mean that the neck should be as straight as possible? It’s currently set up almost perfectly straight, which is why I’m puzzled as to why the saddles are so far back.I don't agree that the current position is normal. While it might not be totally uncommon, it's not the norm and these are getting close to end of the adjustment range.
First thing to do is make sure your neck is straight. It needs far less relief than most people think it does, and for these purposes, start with it dead flat. If it takes a big truss rod adjustment to get it flat, redo the intonation and see where the saddles fall.
Next, measure from the nut to the break point of the saddle. On the high E, that distance will be 25 1/2" plus about 3/32" of compensation. The low E gets about an extra 3/32" of compensation. So 25 19/32". On the low E, that distance is about 25 11/16".
It's rare for a modern CNC-made guitar to have a bridge that's that far off the norm, but it happens, especially with aftermarket bodies.
