Why am I going sharp?
Discussion in 'Bad Dog Cafe' started by Old Deaf Roadie, Aug 20, 2019.
  1. Old Deaf Roadie
    Old Deaf Roadie Tele-Holic
    Oregon
    I started hanging the guitars I play the most from wall hooks about a year ago. I do not know if it is the effects of gravity, or something else unrelated, but these guitars have a tendency to trend toward sharp as they hang. The peculiar thing is that all the strings are in tune with each other, but the result is as if I had tuned a half cent up. The trend toward sharp is not occurring as I play, only when hanging on the wall hooks. It does not occur on cased instruments.
    Any insight as to what is happening here? Am I missing something simple & obvious? I had a medical episode a few years ago that affects my memory & reasoning abilities sometimes and not recognizing the obvious is a thing with me, so please be kind in your replies...
  2. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    I'm thinking tempature change.
  3. ASATKat
    ASATKat Tele-Afflicted
    next to the burn zone
    That always happens acoustic or electric, my G&L solidbody has to be tuned everytime.
  4. E5RSY
    E5RSY Poster Extraordinaire
    Georgetown, TX
    Does the tuning return to where you had them when they are taken off the wall and you play them for awhile?
    Are we talking acoustics, or electrics?
  5. chris m.
    Santa Barbara, California
    Gravity bends the neck straighter and longer.
  6. Lies&Distortion
    Lies&Distortion Tele-Holic
    SE Michigan
    My guess. It's a little colder up on the wall than in your hands. Is it an exterior wall on the other side?
    aerhed likes this.
  7. Torren61
    Torren61 Tele-Afflicted
    Humboldt County, CA
    ... he said, flatly.
  8. Shuster
    Shuster Friend of Leo's Silver Supporter
    Bulverde Tx.
    You're too tightly strung, loosen up a bit, and unwind;)
  9. BelairPlayer
    BelairPlayer Tele-Afflicted
    Ca
    Temperature of my fingertips.
    Ambient temperature in my house.
    As you play, your fingers warm up the strings and the strings expand (lengthen). As your guitar hangs, the strings cool to ambient temperature and contract (shorten) and therefore go sharp.
    CFFF likes this.
  10. 440mhz
    440mhz TDPRI Member
    Elk Lake, On, Canada
    It's also why it's recommended to tune your guitar in the playing position.
    Skydog1010 likes this.
  11. eclecticsynergy
    eclecticsynergy Tele-Afflicted
    Albany NY
    Yep, if there's any relief in your necks gravity will flatten them out, leaving you a bit sharp.
  12. BelairPlayer
    Ca
    If this were the cause, how could anyone ever hang a guitar without having to do a setup each time after retrieving the guitar? You would continually be adjusting your guitars action. The slight pull of gravity will not overcome the truss rod.
    aerhed likes this.
  13. Old Deaf Roadie
    Oregon
    Both electric & acoustic. I have not tried playing to see if it returns naturally. They stay in tune for a couple days, but if left hanging for a few days, they will be sharp.
  14. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    Mine all go slightly sharp with climate conditions if there is much change.
    If I'm not sure if a particular guitar will be played for a week or more
    detune down 2-3 cents. That eliminates some tuning time a bit on next play.
  15. Count
    Count Friend of Leo's
    Tenterfield, Australia
    If you look up the coefficient of thermal expansion of metals you will find a lot of, often incomprehensible, info on the topic. The simple explanation is that variations of a few degrees, often unnoticable to ourselves, will cause strings to expand or contract. You warm the strings when you play and hold the guitar, which is also when you tune it, you then hang the guitar and it cools down slightly, the strings contract and go sharp. My guitars do the same thing in winter, in summer they tend to go flat. Because the strings are fairly similar in diameter, at least the cores of the wound strings are, they seem to all seem to go flat or sharp by the same amount. That's my theory anyway.:)
  16. pixeljammer
    pixeljammer Tele-Meister Silver Supporter
    Colorado
    This happens to my guitars, and they're on stands. I think it's temperature.
    Georox likes this.
  17. telemnemonics
    So you keep loosening the strings and then they tighten themselves up again?
    Very strange.
    If the temp tightens the strings and you loosen them, the temp can't keep making them tighter and tighter while the room doesn't get hotter and hotter.
    If the neck straightens out a little from hanging, it can't keep getting straighter and straighter without getting back bowed.
    I'd call it gremlins, have a nice cbd product and relax, if that's appropriate.
    Wait, if you always tune up to pitch then there can sometimes be a little more tension on the tuner side of the nut, which can pull the note sharp after a while. That's about all I've got though.
  18. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Wait a few months and your guitars will be going flat.
    Seasonal temperature and humidity changes.
    You may notice the 'rosewood' fingerboard guitars are bending around more than the maple fingerboard guitars you have - due to dissimilar wood and lack of fretboard finish to retard expansion/shrinkage of the the necks.
    8barlouie and fatcat like this.
  19. Chunkocaster
    In space with Ziggy
    Mine have been going sharp on stands and laying flat in cases lately. It's been getting cold at night and the days have been just mild. My guitars often go sharp If I don't touch them for a few months. You would think they would go flat due to string tension but the opposite happens.
    I often get lazy and just tune by ear so maybe they creep up over time due to that and I only notice next time I grab one and put a tuner on it.
  20. beagle
    beagle Friend of Leo's
    Yorkshire
    You should try simply walking from one room to another with an old Neapolitan mandolin. You wouldn't worry about your guitar tuning shifting slightly any more.
    Skydog1010 and AAT65 like this.
