Who taught this guy to solder..
Discussion in 'Tele-Technical' started by telekaster1999, Oct 24, 2021.
  1. Censport
    Censport Tele-Afflicted Platinum Supporter
    Nashville/東京
  2. Greenmachine
    Greenmachine Tele-Afflicted
    New Jersey
    The horror. The horror...
    SnidelyWhiplash likes this.
  3. drf64
    drf64 Doctor of Teleocity Silver Supporter
    Ada, MI
    If it sounds good and doesn't hum excessively, who cares?
    dougstrum and yegbert like this.
  4. ChicknPickn
    ChicknPickn Tele-Afflicted Silver Supporter
    Ole Virginny
    Well, I’m feeling a lot better about myself now.
    dougstrum likes this.
  5. Cam
    Cam Friend of Leo's
    Oddberta
    Are you all trying to tell me it isn't the melted plastic coating that holds the joints together? Hoodathunkit? (heh!)
  6. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    Mongo?
  7. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    Players get to that style of soldering when they have swapped a dozen pickups searching for 'the toanze'.
    Rework jobs are the hardest ones to make look Instagram Nice.
    You are trying to clean up the prior poor solder job, make a wiring change, fix faults, with wires that are extra short so you can't cut back to expose fresh wire, prior owner melted the insulation in several locations, or whatever, and it will look more like that example than the soldering done on fresh new parts with new wires using a known/vetted circuit diagram. Those are the solder pictures that easily look so very nice. Factory-clean solder jobs.
  8. archtop_fjk
    archtop_fjk Tele-Holic
    Lebanon, NH
    Well, as bad as that looks, as long as the circuit is electrically correct, the electrons don't care about neatness...
  9. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    TDPRI John?!
    ale.istotle likes this.
  10. John Owen
    John Owen Tele-Afflicted Ad Free Member
    Seattle, WA
    Yep - that's me.
  11. dougstrum
    dougstrum Friend of Leo's
    blu ridge mtn cabin
    Man! That guy is worse than me:confused:
    He brings sloppy to a new level:rolleyes:
  12. kjatexas
    kjatexas Tele-Meister
    I bought an AS Strat off of reverb. The previous owner had glopped so much soldier on the pots, that I could not read the pot codes/dates. As the pots appeared to have been already changes, I bought new CTS 250K pots, and had my luthier install them, along with all new wiring and an orange drop capacitor.
    DanCooz likes this.
  13. Andy ZZ
    Andy ZZ Tele-Meister
    North!
  14. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    Hopefully not a brain surgeon with a hobby.
    But let's all be kind - the person responsible may not have full use of their faculties. Poor vision, Parkinson's, etc. can make it difficult to enjoy a hobby such as this. If it was a professional guitar tech - shame, shame, shame...
  15. ashtone54
    ashtone54 TDPRI Member Silver Supporter
    Colorado Springs, CO
    I’ve seen so many like that…and I did the same kind of lousy work when I was a kid.
    Soldering isn’t difficult; it’s just physics. You don’t melt the solder with the iron, you use the iron to get the work hot enough to melt the solder. That’s why they used actual irons back in the day. It only takes a couple seconds to get a pot case hot enough to solder down ground wires with an iron, or a Strat trem spring claw plate.
  16. buzzword
    buzzword TDPRI Member
    Los Angeles
    You can’t unsee that. On the other hand it makes mine look like it was done by magic elves, so there’s that. :rolleyes:
  17. jkingma
    45°54'36.6"N 79°59'11.5"W
    Admin Post
    I was going to say the same thing...
  18. cpk313
    cpk313 TDPRI Member
    Allentown PA
    Damn, you should have added a NSFW to your post with a picture like that!
  19. Marblatx
    Marblatx Tele-Meister
    Austin
    Good thing bad solder joints are easy to fix.
  20. MoHump
    MoHump TDPRI Member
    Vermont
    Wicking, bird cage, to much solder, etc. It's not so much the mess of flux left, but solder does not make a good mechanical connection. I learned to solder in a NASA soldering school, the right way. Clean joints, tin the wire, bend into a hook, hook it into the pots lug, crimp it tight, small dab of solder on the irons tip, touch it to both the lug and the crimped wire, add just enough solder to fill the hole, Done! Do all of this in a smooth confident manner (sorry, just had to say that, LOL), don't want the solder wickiing up the wire and melting the wires insulation. Moving the wire after doing that causes the strands to separate causing a 'bird cage' effect; just what it looks like.
    Telecentric, Tony474 and StoneH like this.
