Who has purchased a Roasted Maple Neck? Thoughts?
Discussion in 'Other T-Types and Partscasters' started by 4pickupguy, Jan 18, 2017.
  1. Mistercharlie
    Mistercharlie Tele-Holic
    Germany
    Music Man does it like this:
    - Put a little oil on a paper towel
    - Rub it over the neck
    - rip off another paper towel
    - wipe oil off neck
    Then they do the same with the gunstock wax.
    I did my roasted maple neck this way and it's fantastic. It's not glossy or silky. It just makes the wood smoother, and also makes it look nicer. No need to sand, no real need for more than one coat. As you're doing it at home, instead of on a production line, you can also wait a week between oil and wax applications, but that's also unnecessary.
    Roasted maple won't absorb moisture anyway, so you don't need to do this, but I guess it keeps the dirt off.
    the tool likes this.
  2. bodevelho
    bodevelho Tele-Meister Ad Free Member
    EUA
    several, I like them with tru-oil, it doesn't darken that much but it adds depth and feels nice
  3. the tool
    the tool Tele-Holic
    Sweden
    Ahh! i didn't know roasted maple doesn't absorb moisture :) Thats good to hear.
    I don't think i will do the fretboard.... because of frets and all.
  4. stefanhotrod
    stefanhotrod Tele-Holic
    germany
    My Warmoth neck arrived...
    ...and man, what a thing of beauty!
    Meanwhile I tend to leave the fretboard completely unfinished and treat it like a rosewood board with a bit of real fretboard oil every now and then.
    Some questions (and sorry if they‘re already answered somewhere):
    • My neck screws got a 4.0 mm diameter, the neck holes are 3.0 mm predrilled. Am I good to go or do I have to enlarge the holes a bit since Warmoth recommands „one size larger“ (whatever that means)?
    • Are Warmoth necks sealed in any way?
    • Will sanding change the color of the roasted maple significantly?
    Thanks for help, gentlemen!
    Flaneur, BigDaddyLH and weevilcaster like this.
  5. RLee77
    RLee77 Friend of Leo's
    Nevada
    Stefan, that neck looks amazing — we need to see more of it!
    stefanhotrod likes this.
  6. stefanhotrod
    germany
    Thanks!
  7. Blue Bill
    Stefan, that looks great, that stripe is very dramatic. I don't know if sanding will change the appearance or not. I always clamp the neck into the pocket, before starting to put in the screws. The danger with too small holes is, if the two joining surfaces get pushed apart when the screw tip exits the body and enters the back of the neck, there will be a gap between the two when the screw is fully sunk. Continued tightening may suck the two together, but it will tear some wood fibers, weakening the wood touching the screws. It's best to size the holes in the body big enough so that you can almost push the screw right through it. The holes on the back of the neck should be smaller, about 30% smaller than the screw diameter, so the wood is compressed as the screw is twisted in. Clamping will prevent any gap from opening up. Good luck!
  8. 4pickupguy
    4pickupguy Doctor of Teleocity Silver Supporter
    Fort Worth, Texas
    Its been a year (or better) now since I bought my first roasted maple neck. This thread came up in my notifications and I thought I’d give an update. The neck feels better with each passing day. Dont think I will ever buy anything else. It is much darker now than when I first got it. I love It!! IMG_0958.JPG
    El Tele Lobo likes this.
  9. stefanhotrod
    germany
    The neck is superbly smooth out of the box, do I need to sand before applying Truoil or is just a naphta wipe enough?
  10. nosuch
    nosuch Friend of Leo's
    Cologne
    If it's more brittle – does it break sooner e.g. if your guitar falls from a stand or is it just that you have t take more care putting screws in it?
    BuckSatan likes this.
  11. stefanhotrod
    germany
    It‘s just the screws, they need proper, correct sized holes.
    smallbutmighty likes this.
  12. Norrin Radd
    Norrin Radd Tele-Holic
    Saint Paul
    I ordered a Musikraft. I'll be back in ~4-6 weeks with an update. ;)
    4pickupguy and stefanhotrod like this.
  13. jrblue
    jrblue Friend of Leo's
    Santa Barbara
    It's an excellent neck material. How it plays depends on (1) your ability to order a shape and radius that works for you, and (2) how you finish it. Personally, I think EB/MM has the neck treatment absolutely nailed. Their wax/oil treatment serves as a finish (keeping moisture out, eliminating climate effects that can alter the relief pretty readily) with zero buildup and, IMO, the ideal balance of feel and speed. They are also beautiful. Some roasted necks get pretty dark and the color doesn't always fit in with the rest of the guitar.
  14. stefanhotrod
    germany
    Absolutely true. The roasted necks from Warmoth are pretty dark- they look like they’re more than fifty years old. I like that a lot, but it‘s a matter of taste.
    My neck fits perfectly with my faded sonic blue, nitro cracked/light reliced thinline body. Meanwhile I guess the neck will get some light coats of Truoil, nothin beats the feeling of a silk buffed Tru-oiled neck (like EB/MM), but I‘ll leave the fretboard unfinished (except every now and then a bit fretboard oil).
    Still unsure if I‘ll have to sand the neck before oil applying (teach me!) and a but afraid of drilling the tuner holes :rolleyes:
    4pickupguy likes this.
  15. Norrin Radd
    Saint Paul
    I wouldn't sand it unless it needed sanding (which I doubt). When I did the Truoil on my last maple - I didn't sand between coats and it came out perfectly.
    BTW, that is going to look killer when it's completed! What's the rest of that build entail?
  16. 4pickupguy
    Fort Worth, Texas
    Slightly larger screw pilot holes and it would’nt hurt to lightly do the beezwax thing when installing them the first time. I ended up putting knife thread inserts (somestimes called softwood inserts) from McMaster Carr with really oversized holes for the inserts. I then potted them in with an epoxy. This allows me to use 10-32 aviation machine screws (MS27039’s).
    I did not finish mine at all and its doing just fine.
    I bought a one piece (no separate fret board) solid rosewood neck from Warmoth that cost me 3 times what the roasted maple did and although its a fantastics neck, I really like the roasted maple neck. Feel and weight are better IMO.
  17. stefanhotrod
    germany
    Thanks! A handbuilt swampash body with a maple top (1.4 kg), angled neckpocket for a B16, ultrathin nitro lacquered. Still undecided with the Pkups, maybe Barfuss from germany, anyway vintage types, maybe unwaxed.
    4pickupguy and Norrin Radd like this.
  18. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    The wavy grain fooled me at first - my eyes were tricked into thinking the last 5-6 frets were scalloped.
    I currently have no "need" for another neck [pausing for laughter] but if/when I do, expect a distraught thread, asking about Roasted Maple vs All Rosewood.
    And in return, shall expect sympathetic responses, leaning towards: "aw heck - go for two..."
    Peace - Deeve
  19. El Tele Lobo
    El Tele Lobo Poster Extraordinaire Silver Supporter
    I can’t speak to either of those neck types…yet. But can I just go ahead and throw my vote in for “go for two”? [emoji6]
  20. stefanhotrod
    germany
    Interesting answer from Warmoth:
    „We recommend that if you are to finish one portion of a neck then the rest of the neck should receive finish as well. Ultimately when you apply finish to only one section of a neck you increase the chances of it warping or twisting as the rest of the neck will not expand and contract with fluctuations in temperature and humidity in the air at the same rate. Doing so would also void your warranty.“
    My plan was to leave the fretboard unfinished and Truoil on the rest...not sure if the recommendation above applies also for 2-piece maple necks?
    Uh, by the way, what do you guys think about the frets:
    They need a final polish of course, but do they also need (more) crowning?
