Who else counts how many things are plugged together just for your rig?
JohnFender
I think I spend more time thinking about signal path from the guitar to ear including all the components inside our powered equipment and wonder how is it possible for everything to pass through going from sound to a magnetic frequency powered then reversing back to sound as fast as the speed of light then I put my guitar down and count how many pedals, amps, effect processors and recording devices altogether about 15 is that normal?
G Stone496
NYC
northernguitar
North of Toronto
True bypass and buffers keep your guitar signal strong and keeps the pedals in your chain from weakening or degrading your guitar signal.
They’re two different things. One boosts the signal in bypass the other doesn’t.
G Stone496
NYC
Did not say otherwise. True bypass decreases the amount of signal loss from pedal(s) when the pedal is turned off but still in the chain. A buffer in a pedal increases the amount of signal from input to output of a pedal. Both fight signal loss but in different ways.
String Tree
Up North
Apparently, it is 'Normal' for You.
That is all that counts!!!
Me, I'm at 5 and a Tuner.
That is my 'Normal'.
~ST
bottlenecker
Wisconsin
Pedals that don't have true bypass have buffers. It's one or the other. That's why it doesn't make sense. That article is poorly written.
Frodebro
Seattle
A true bypass pedal mechanically bypasses all circuitry when the pedal is disengaged, and is essentially electronically "invisible" in the signal path when bypassed.
A buffered bypass pedal has circuitry that remains intentionally active when bypassed in order to retain signal integrity over longer cable runs.
A non buffered, non true bypass pedal will still have some circuitry active in the signal path when bypassed, but it can often degrade the signal quality to some degree, particularly with long cable runs.
True bypass became the hot buzzword years ago when buffers weren't quite as good as they are now, as it was viewed as the best option at the time.
Twang-ineer
OP, I read your post. 15 conversions I would think is about average. With a single pedal inline, you have a minimum of 10 conversions/modifications. And that is only counting broad brush "stages" not components.
And yes I too marvel at that wonder of physics... transducing, transcoding, reassembly, processing, conversions of signal type etc. just to get the vibrations of the string through the path, through the room and into the ear in a matter of milliseconds.
swarfrat
Not signal but I sometimes think about sticking one of those power measuring circuit breakers in. I'd love to know what the actual usage is.
