Which Telecaster to get?
Guitars2022
Los Angeles, California
I currently own a Baja Tele. I prefer bigger necks on guitars. Looking for another telecaster to add to my collection. Any recommendations for one which is versatile and also well built. I was not impressed with the player telecaster because I did not like the modern c beck and the pickups were unimpressive.
LOSTVENTURE
Charlotte, NC
You might want to check out one of the Nashville variants. I also have an early (2006) Baja, and still find lots of uses for the Nashville. It's sort of a "Strat" precursor.
mimmo
Paris France - Rome Italy
I hear you. I have an AV52 and I also prefer bigger necks. Depending on your budget, if you want to buy new your only options are a Vintera 50s (I prefer the standard model with 7.25" radius) or the AO 50s which is similar to your Baja, has nitro finish and flatter radius (9.5") and (I think) bigger frets than your Baja (I may be wrong)
fenderchamp
omaha
The anniversary esquires are about the nicest regular USA fender they’ve made in a long time, particularly if you don’t care for modern slanted models.
Mike_LA
Just past 11 on the Dial
Set Neck
Bound neck and body
I changed the pups out for SD Phat Cats, the instrument ROCKS
FTM Search on Reverb
https://reverb.com/item/56648636-fender-special-edition-set-neck-custom-telecaster-hh-fmt-2003
Killing Floor
Austin, TX
Why I love the Fender Mod Shop. I like C necks. I like being able to choose pickups and hardware. They only seem to stock the same colors and I like the choice. 41 Fender colors on Mod Shop. Takes about a month and it’s a semi-customized MiA. And they don’t cheap out on the case.
fenderchamp
omaha
The mod shop is really cool. though, after having built my own for so long, the options seem very constrained to me.
@Controller I love black blackguard style teles, they are so tuff! I must have one sooner or later.
I didn't know they made a 50s style mim classic in black nitro though. I remember they had a blonde or white one for a while, and a CAR strat both in nitro. Other than that, I don't remember any, not that I have an encyclopedic knowledge of the last 25 years of the MIM catalogue or anything.
Otisblove
Greenfield, Indiana
If it doesn’t HAVE to be a fender, I bought an allparts fat neck from a seller on eBay that claims to level and crown the frets as well as cut the nut. It’s fantastic. Baseball bat for sure. You can put it on any body you like.
Fretting out
Platinum Supporter
Land of Mary
I have a theory and may be off base but unless you’re buying in person I wouldn’t get anything newer than 2018, seems like QC is hit or miss and will probably be so for the next couple years
The model depends what else you are looking for, as in fingerboard material? Vintage/modern style? Price range?
Alex_C
If you are OK with a non-fender Tele, Kiesel offers a fatter neck option for a $60 upcharge. If you go with standard options, you'll be at $1800 or so. Kiesel guitars are stellar instruments.
doctymie
St Louis
Vintera 50s definitely. If you can find a 70th Anniversary Broadcaster, those fit the bill as well.
I have both and I find the Vintera 50s is slightly chunkier than the Broadcaster. But both are quite comfortable.
Guitars2022
Sounds like the fender vintera 50s or fender Esquire 70th anniversary are the best options? Is the fender vintera overpriced? Sounds like the Esquire 70th is better value and more vintage sound?
