Which STRAT Neck Pup with Jerry Donahue Bridge?
Discussion in 'Just Pickups' started by Hoodster, Mar 29, 2020.
  1. Hoodster
    Hoodster Friend of Leo's
    Oregon
    I've had my Tele set up as an Esquire with the JD for probably 10 years (fabulous), but recently decided to try a Strat neck pup and installed a Duncan 5-2.
    The 5-2 is nice and the middle position is particularly sweet, very Stratty, but it's more usable than the neck alone, which is not what I expected. I was hoping for a bold classic Strat neck tone like I get from the Fender 69 in the neck of my Strat.
    I'd really like to stick with Duncan in order to be RWRP with the JD. Any thoughts on alternatives from SD? I've had SSL-1's before and I think they're quite close to the 5-2.
  2. DrB
    DrB Tele-Meister
    Istanbul
    Surfers are quite good!
    B
  3. Mincer
    Mincer Tele-Holic
    Tampa Bay Area
    I'd consider either the Antiquity II Surfer, or the SSL-2 (for more of a 50s clean, clear Strat sound).
  4. SPUDCASTER
    Grangeville, Idaho
    I think Jerry used the Alnico II Pro. Depending on your radius as to which one you'd choose.
  5. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    I paired my JD bridge with a mini-hum in the neck! Very good combination, IMO.
  6. 8trackmind
    8trackmind Tele-Afflicted
    Dark side of the moon
    I like the SSl 1 in the neck on strats but, I pared my JD with a with the alnico 2 strat pickup on my nashville. I
    think the perceived brightess is the key.
    If you believe the guitar to be on the bright side, and you tend to play on the cleaner side, I would go for the Alnico 2.
    If you're running your amp hard enough that it's saturating the power tubes, you'll need something brighter like the SSL1. My opinion only, but I gig small amps run hard and favor the cut of A5 in a band situation.
  7. Hoodster
    Oregon
    Thanks, guys. I lowered the 5/2 a bit and I’m liking it better. It is, after all, a combination of two pretty great pickups, the SSL1 on the low strings and Alnico 2 pro on the top.
    On a related topic, I have an SSL5 in the bridge of my Strat and I’m curious if anyone has ever tried one in the neck position.
