Which resistor do I remove?
Discussion in 'The Stomp Box' started by joel_ostrom, May 16, 2013.
  1. joel_ostrom
    joel_ostrom Tele-Afflicted
    Calgary, AB
    I'm trying to install the Deville Clickless bypass mod in a Boss CE-5 Chorus Ensemble pedal. The instructions indicate that I need to remove. I've attached the installation guide, indicating which resistor needs to be removed, as well as the schematic for the pedal itself.
    Could somebody point out which resistor on the pedal schematic correlates to the resistor in the installation guide that I need to remove?
    Thanks!
    Boss CE-5 Chorus Ensemble Schematic
    Clickless Tru-Bypass Installation Guide.
    Red arrow indicates the resistor I need to remove.
