I've search the web, and the Les Paul forum, and done a ton of reading, but I don't know much about which bridge to get. The stock bridge that's on it has become "wallered out" and moves around on top of the threaded screws, resulting in not being able to stay in tune.
One look at my Les Paul, and you'll notice that it's anything but traditional. It's a LP Standard body, with a LP Custom neck - from the factory that way. I've had tons of pickups in it, but settled on EMG 89s. This guitar sounds so good to me
Also, have factory installed Sperzel tuners, and replaced the stock 3-way toggle with an Ernie Ball / Music Man all metal heavy duty switch.
So I have no care about doing something traditional, simply because it's the closest to a vintage spec.
I need a bridge that is the most stable there is, that stays in solid tune. I don't remind replacing the stop bar if it helps, or comes with the bridge.
Thoughts?
Thoughts?
