Which primer colour?
Discussion in 'Finely Finished' started by Darrenr75, Aug 9, 2020.
  1. Darrenr75
    Darrenr75 TDPRI Member
    Portsmouth
    I’m going to be spraying my strat body a metallic dark blue colour soon, and wondered which colour primer I should use? Grey or white?
  2. Zepfan
    Zepfan Doctor of Teleocity
    Horn Lake, MS
    Dark color = light primer
    Light color = dark primer
    The contrast helps with spraying to see your coverage.
    But that's up to you or if you want to change the color tint. White primer base will be easier for you to see your passes while spraying, but it can make the color a bit lighter in the end unless you give it a extra coat or 2. Grey primer will make it look a bit darker but may not make any difference at all depending on how thick the color is.
  3. Jim_in_PA
    Jim_in_PA Tele-Afflicted Silver Supporter
    SE PA near New Hope PA
    Personally, I use grey primer for situations like this.
  4. koolaide
    koolaide Tele-Holic
    south carolina
    Gray or Silver. a silver under coat is what would likely be used under a blue candy color.
    Cali Dude likes this.
  5. Darrenr75
    Portsmouth
    Thanks for the advice. I’ll go for grey.
    my next problem is that I can’t seem to find any decent metallic dark blue paint anywhere - they all seem to be either daphne or Pelham blue which are far too light.
    Any help on this one?
  6. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    Is this dark enough?[​IMG]
  7. Darrenr75
    Portsmouth
  8. Cali Dude
    Cali Dude Tele-Meister
    California
    Silver.
