Which fuZZ pedal will help me get an Eric Johnson type lead tone??
  • Thread starter jalguitarman
11 Gauge
Near BWI Int'l
Silicon Fuzz Face with lower gain transistors (I'd avoid RI's and probably get a clone made by someone other than Dunlop).
Eric's tones seem to be a bit more in step with Hendrix's BoG stuff, which was silicon fuzz - not germanium.
Two things that Eric's FF's seem to have that differ from stock are BC183 or 2N222 transistors and a 100K output pot. There may be other things, and his latest pedals may have different transistors. Since they are silicon, they aren't as critical IMO, as long as the gain is low - nothing like the MPSA18's in the Dunlop JH2 (horrible, IMO). The different output pot will make a FF a bit brighter, but I wouldn't constitute it as a deal breaker. Silicon FF's are already bright!
IMO, higher gain transistors will make a silicon FF sound like something other than one. Just do a bit of googling to learn more about what transistors clone builders currently offer.
Also, fairly recent experimentation seems to have revealed that 2N2369/PN2369 (MPS2369 transistors from Radio Shack if they have them), will give you a tone about halfway between the Hendrix/Johnson silicon one and the original germanium FF, which will give some additional flexibility (better "cleanup"). But you will lose a bit of the snarl and bite that the "proper" silicon transistors will provide. They are very low gain - almost the same as "good" germanium transistors.
Why am I giving all of this info about transistors? Because that is about 85% (some would argue more) of what gives a FF it's sound, so the transistors are very important. Any good clone builder will highlight this almost immediately. Good luck!
pistolsteve
Tulsa, Oklahoma
Lovepedal 200 Lbs. of Tone I think does a good job of emulating Eric Johnson. Not sure they make 'em anymore, but I'm sure you can find one used if you do some searching.
jalguitarman
O'fallon IL
I have considered a sunface pedal. I also wish they still made a fulltone 69. I would try that one as I bet it would get me close. I would also love to have an adaptor that simulates an almost dead batterey. I know that i notice a difference in my jazz bass w/ active electronics when I use a standard battery vs a heavy duty battery. With a standard battery the tone is smoother, better in my opinion. I am hoping in trying to get Eric Johnsons tone I discover my own tone. I do know a standard od/distortion wont get the job done for me.
Thanks guys.
shades
Pittsburgh,Pa.
A Fulltone 69 will get the tone. The germanium components have a mind and life of their own like few other stomp boxes. Use regular 9 volt batteries as they work better than an alkaline.Save your nickels & dimes, the 69 is worth every dollar when you find one. I lucked onto one at my favorite music store in the used pedal case and grabbed it right away. Ebay sellers get kind of nuts with used Fulltone gear but you'll find a deal from time to time.
:cool:
schenkadere
NY
Jetter Gain Stage Blue...that's what it was designed for.
(link removed)
mojoming
United States
Those use germanium transistors. Eric's signature tone is from his use of silicon Fuzz Faces.
That Das Fuzz has that feature built in.
metulmykul
Brisbane, Australia
I came across this on another forum...
I believe this to be EJ's tech sorting through Fuzz Faces
image removed
A tweaked FF woukd be a good starting point.
