Which current production neck shape is closest to a 60's strat?
Discussion in 'Stratocaster Discussion Forum' started by backalleyblues, Nov 21, 2021.
  1. backalleyblues
    backalleyblues Friend of Leo's Silver Supporter
    Jacksonville, FL, USA
    good morning everyone!
    I'm looking to replace the neck on my partscaster strat, the current neck on there (an old Mighty Mite neck) is just too flippin big anymore for my hands, as it's probably .95" at the nut. I'm totally in love with my '77 telecaster neck on my frankenstein telly that I found earlier this year, which is very close to a classic 60s telecaster, 1.65" wide and probably .85" thick at the nut with a round C profile, and it stays pretty slim up the neck.
    So who makes a neck currently that matches that spec, and what do they call that? In my case, I also would prefer a rosewood fretboard (slab or veneer, both are fine to me) and jumbo frets, since I use a LOT of bends in my playing.
    Thanks in advance,
    Franc Robert
  2. cherryburst1
    cherryburst1 Tele-Meister
    If you have the bucks and want a really slender neck, order a Warmoth with the wizard profile. It's a little slimmer than a '80's Fender "D" profile....
  3. backalleyblues
    Umm, that's not what I'm after-I want the classic 60's C shape, MOL. My '77 pretty much nails that (complete with a refret with jumbo frets!) and I want the same for my strat...
    Franc Robert
  4. Murphcaster
    Murphcaster Tele-Meister
    W.V.
    60s Oval or '69 U (don't let the U profile fool you. The '69 strat version is relatively slim and even tapered).
    Maguchi and backalleyblues like this.
  5. cherryburst1
    MM2929-R Mighty Mite neck. .82 at nut, .87 at 12th fret, 1.69" wide at nut, rosewood fretboard and jumbo frets. See their website for more info.
    Greggorios likes this.
  6. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    I've used a couple of the Allparts SRO-C necks which I quite like. 10" radius.
    Allparts specs-
    21 tall frets, fretwire = LT 0465-000, width: 2.0mm x 1.30mm (.079" x .051"), modern
    Solid maple neck, sanded, unfinished and ready to spray
    Rosewood fingerboard
    10" radius
    Nut width 1-5/8"
    Heel width 2-3/16"
    Tuning Peg Hole Diameter .340"
    Truss Rod adjustment at heel
    Neck thickness .86" at first fret, .96" at twelfth fret
    The rosewood looks very light at first, a but a quick coat of boiled linseed oil sent them pretty dark.
    If you can find one, Hosco does one with an almost identical spec only with medium jumbo frets.
    tintag27 and KelvinS1965 like this.
  7. Maguchi
    Maguchi Tele-Afflicted
    Lalaland
    Hmm, sounds like a good suggestion. Thanks. Do you think it would work with Pau Ferro? How did you apply it? Just put a little on a rag and rub it into the fretboard?
  8. Uncle Daddy
    Maldon, England
    I did just that, and patted it down after with some kitchen paper. I threw the paper on the fire, linseed oily rags and paper can be a fire risk.
    I'm not sure how much linseed oil will darken pau ferro. One rw neck I got had very pale wood- it looked almost lilac in colour. The oil brought it down and highlighted the grain nicely.
    Another one is almost black-
    Both started pretty pale when they were dry.
    Maguchi and Telekarster like this.
  9. Telekarster
    Telekarster Friend of Leo's Gold Supporter
    Earth
    Always good to keep this lil safety tip in mind! Appreciate the reminder ;)
