Which attenuators do 65 Deluxe Reverb Reissues work well with ?
Discussion in 'Amp Central Station' started by Bad Penny, Mar 7, 2021.
  1. Bad Penny
    Bad Penny TDPRI Member
    Ballyshannon
    I understand they can be a bit picky with attenuators.
  2. Torren61
    Torren61 Poster Extraordinaire Gold Supporter
    Humboldt County, CA
    I don’t know the answer to your question but an attenuator is one option where there are many options to lower the sound of a fully cranked amp. A Fryette Power Station is another. It’s a reactive load as is a Two Notes Captor X as is a Rivera Silent Sister isolation cab. I’ve been through attenuators and I like these other options better. I still have a Weber though.
  3. johmica
    johmica Tele-Holic
    Berea, KY
    I installed a Brake Lite on mine. Before I mounted it to the inside of the cab, I played my tele both through the Brake Lite and with the amp fed directly into the speaker. To my ears, the Brake Lite affected the tone only at the lower registers (on setting 4, for example).
    I've got it installed now, set on 2, and my DRRI is my #1 practice amp. I play it daily, and the only difference I can hear between the attenuated signal and the direct signal is the volume. To my ears, there is no difference in the tone whatsoever.
    I'm probably not as picky as some (in other words, my ears are likely not as refined as other, more experienced players), but I tried to hear a difference in sonic quality between having the amp hardwired and playing through the Brake Lite. I could not tell any difference at all in the 0-3 range.
    Ed Storer likes this.
  4. Cali Dude
    Cali Dude Tele-Afflicted
    California
    I think that the Tone King Ironman 2 is a great one.
    Tim S likes this.
  5. scooteraz
    scooteraz Friend of Leo's
    Peoria, AZ
    Rivera Rock Crusher.
  6. hotcoffeenochill
    hotcoffeenochill TDPRI Member
    Rhode Island
    I use a Weber Mini Mass w/ my old DR. I like that it’s got a knob for attenuation instead of just switch, works great for live stuff when they ask you to just take it down a touch and for home when you need to really bring it down.
    Pcs264 likes this.
  7. bluesholyman
    bluesholyman Friend of Leo's
    Salt Life, Gulf Coast
    Dr Z Brake-Lite and Air Brake are great. As @johmica noted above, its only at the lowest setting where the sound of the amp is altered slightly - I have experienced the same thing, but on a Mesa California Tweed (40w.) I haven't personally tried it with a DRRI myself, but I think it would work great.
    I currently use a Captor X on my California Tweed and it does just fine. I switched so I could track the amp silently when I need to. I had no issues with the Dr Z attenuators.
  8. mabley123
    mabley123 Friend of Leo's
    ashland kentucky
    SPL Reducer
    Power Station
  9. rze99
    rze99 Poster Extraordinaire
    South London UK
    Same here.
    works well also have a TDH Hotplate also works well.
    try to find used as I did keep the price down.
    hotcoffeenochill likes this.
