Where to place Tremolo footswitch jack
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, Sep 15, 2019.
  1. ArcticWhite
    ArcticWhite Tele-Holic
    Portland Oregon
    I'm converting this nifty little Silvertone amp into a guitar amp.
    Can't figure where in the circuit I should place an interrupting jack for my tremolo footswitch.
  2. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Lifting the connection to ground for any of the 3 resistors in the oscillator (R19, R20, R21) should kill it. I think the trick here is you want to lift those grounds without affecting the cathode grounds for V1B and V2B.
    Maybe give R21 it's own connection to ground and put the kill switch between R21 and ground? Whichever one makes the most sense, depending on the layout.
    ArcticWhite likes this.
