itsGiusto
For various reasons, I want to add some relay switching to my Revibe build, and to power the relays, I'll need to have an additional power transformer mounted, Dumble-style. But unlike Dumble, there's no room inside the very small chassis, so I think I need to mount it outside, with the rest of the transformers. I'm generally uncertain what are the rules I should follow for mounting transformers.
Here's a shot of the current transformer layout, with me also holding up an additional 6v transformer that I want to mount for relay power.
For what's currently mounted, from left to right, we have the the existing PT, the choke, then the OT to drive the reverb tank.
Here's a shot showing more detail around the PT area.
Do I need to mount the new PT in some particular orientation compared to the other transformers, for less interference?
I could maybe move the choke to the right, and then mount the new PT in its place. But would that put the choke too close to the OT? Also, then would it be important for me to splice extensions onto the new PT's primary leads, so I can send them through the same grommet as the original PT?
Alternatively, I could move the choke over, but then also drill a new hole with a grommet for both the secondary leads from the new and old PT below where the original one was, and kinda mount the new 6v PT over the old hole for the secondaries. That would allow me to get the PT very close to the other PT.
Generally, any advice is appreciated! Thanks!
