Where to find a fuse for my amp???
Discussion in 'Amp Tech Center' started by lookslikemeband, Feb 4, 2014.
  1. lookslikemeband
    lookslikemeband Tele-Holic
    CO - again
    Today I was testing out a guitar I'd worked on.... and ... my Bogner stopped working.
    No loud noise, no pop, no hum, no weird smells.. Still powers up, lights up, changes channels; etc. But no output.
    I changed out guitars, cables, speaker cabs.. EVERYTHING I could think of. Swapped out tubes.... nothing.
    I e-mailed Bogner about it and they said to check the HT fuse. It looks blown.
    Apparently I need to find some 3AG Slow Blow 1.0A fuses. I looked online and I can order them. Any ideas if local electronics stores might have them??
    Thanks!
    (oh man... pleeeeeeeeze be a fuse and not something I have to send to Bogner to fix!!!)
  2. MickM
    MickM Friend of Leo's Platinum Supporter
    A steel guitar engagment.
    Radio shack has them and sometimes you can scare 'em up at a high end stereo or car stereo store or installation shop.
  3. soulman969
    Englewood, CO
    Radio Shack is one place and an Auto Parts store is another. They're actually pretty common.
  4. SamClemons
    SamClemons Poster Extraordinaire
    Jasper, TN
    Many hardware stores would have them. I probably have one or could get it.
  5. lookslikemeband
    CO - again
    Thanks everyone! I'll look at Radio Shack tomorrow and report back!
  6. codamedia
    Western Canada
    Those types of fuses are very, very common. Radio Shack, or any electronic store will likely have them in stock.
    Something nobody else has mentioned - so I will!!!!
    DO NOT use the wrong fuse - especially larger... (ie: A 2amp is a LOUSY replacement for a 1amp!) That fuse blew for a reason and protected the amp by doing do. If you put in the wrong fuse the amp may be the next thing to blow.
    3AG Slow Blow 1.0A
    3AG = The shape and physical size of the fuse (aka: the form factor)
    Slow Blow = This means it will handle spikes over the rated current, but not continuous use over the rated current.
    1.0A = The rated current is 1 AMP.. Never go higher than this rating.
  7. lookslikemeband
    CO - again
    This is good info!! Thank you!
    Heading to Radio Shack NOW.
