where is the bias resistor on a DRRI?
Discussion in 'Amp Tech Center' started by tedro, Feb 24, 2015.
  1. tedro
    tedro Tele-Afflicted
    7th Galaxy
    thanks in advance.
    edit: i mean the resistor which value can be changed--so the adjustment pot's range can be altered..
  2. waparker4
    Philadelphia, PA
    If you lay the the amp down on its face, on the chassis there is a 1/4" jack looking thing with the pot inside, I think a flat head screwdriver operates it. Things are tight, I used one of those sets of plastic screwdrivers that are about 5" long.
    Hopefully someone will correct me if I'm wrong, I remember clockwise cooling down the bias and counter-clockwise heating it up.
  3. tedro
    7th Galaxy
    sorry, waparker, i didn't mean the adjustment pot, i meant the resistor that can be changed--to change the pots range. ?
    you're correct on the over/under direction, ;-)
  4. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    You know I can never rember which way to turn the bias pot ! What I do is hook the voltage meter with no tubes in the socket and check the bias voltage while slowly turning the pot. That way if there's dirt in the pot or a bad spot you'll see it on the voltmeter instead of on the red plates of the tubes. (that pot doesn't get turned often so dust or whatever can build up inside)
    More negitive voltage is cold like -40 and less is hot like -10. I set it all the way cold then put the tubes in and bias them.
  5. waparker4
    Philadelphia, PA
    R59
  6. BobbyZ
    Snellman MN
    Whoops your after the range resister. I'm not sure on the reissuies.
  7. tedro
    7th Galaxy
    and is that a typical resistor sitting on there, that can be changed? although, i have UNsoldered from the board...i was unable to resolder to it. :( any advice, i need a lower value?...to under bias further (hotter). thanks.
    btw, you that cage they put in now, behind the power tubes, mounted on the standard back board?
    it's ok to remove those, right? they only did that so ppl won't stick their hands up there when hot, right?
  8. Wally
    Editted due to lack of mental engagement on my part in that post.
  9. Jack Hester
    Jack Hester TDPRI Member
    Roxboro, NC
    Is there a schematic handy? I'd like to see the Bias supply.
    Jack
  10. Wally
    Google Schematic heaven...go to Fender...go to Deluxe Rever Reissue..under the Reissue heading on down the page.
  11. Johnny Cache
    Johnny Cache Former Member
    Oregon
    +1 This ^^^^^
    If I remember it's 22K if you replace it with a 10K the vari-pot resistor works better. You could just piggyback another 22K on it in parallel which comes out to 11K, that's what I did on my DRRI when I upgraded the PT to a Hammond.
  12. tedro
    7th Galaxy
    thanks a lot guys.
