Where in the fx chain would you put a tc sub'n'up octave pedal
Discussion in 'The Stomp Box' started by Buzzgrowl, Jun 8, 2019.
  1. Buzzgrowl
    Buzzgrowl Tele-Meister
    Switzerland
    Where in my fx chain would you put a TC Electronic sub'n'up octave pedal? The lineup of my pedals/fx is:
    Polytune > Morley BH2 > Boss CS2 > TC Mojomojo > RAT > Phase90 > Ibanez Bi Mode Chorus > TC Alter Ego > Strymon Flynt > Ditto looper.
    Grateful for any advice!
    Cheers - Buzzgrowl
  2. Silverface
    Lawndale CA
    The octave needs to be first or second (after a tuner, wah or envelope filter is OK ) or it will not trigger properly. absolutely MUST be before the compressor!!!!
    In your case I'd place it before the wah. You can try it directly after, but IMO it should be more accurate if it's first in the "effects" chain. Octave and envelope filter/auto wahs are very sensitive to pick attack and need to always be the first or second effects - in SOME cases a wah can go in front, but not very many. But the wah *should* be the next pedal in the chain.
    Buzzgrowl likes this.
  3. wulfenganck
    wulfenganck Tele-Holic
    Seligenstadt, Germany
    I agree with Silverface. I have my octaver first in line after guitar. I tried it after my wah pedal, but the tracking was horrible when the wah was activated, lots of glitches and the tone cutting off. Octavers need a guitar signal as pure as possible.
  4. Buzzgrowl
    Switzerland
    Will do that, first after the tuner! many thanks! Will let you know how it went.
    Cheers, - Buzzgrowl
  5. thechad
    thechad Tele-Meister
    Kamloops
    another thing to consider is the sound you get from the octave pedal before vs. after a distortion pedal. I have mine in the chain before the distortion because then if I turn on both I get a distorted octave sound. If I put the octave pedal after the distortion, it gets a synth type vibe to it. Not what I am after but some people might.
    When I first introduced my octave pedal (ehx pitchfork) I had it right before my distortion pedal and after a few other pedals. It was really noisey so I moved it near the front of the chain (after wah and tuner pedal) and the noise diminished significantly.
    Sometimes you might have to pick the lesser evil depending what you want
  6. black_doug
    black_doug Friend of Leo's
    Toronto, Ontario, Canada
    20180103_021439_HDR_Film2.jpg My T-Rex Quint octave pedal is placed right after the tuner. It works just fine there.
  7. Buzzgrowl
    Switzerland
    Follow-up... the TC Sub'n'up (mini) worked fine as the first pedal. Thanks to all of you for the advice!
    Cheers - Buzzgrowl
    black_doug likes this.
  8. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
    It depends on how it operates. An analog octave pedal needs a clean signal to track properly. A digital octave pedal (HOG, POG, etc) samples the incoming signal. This means that the signal doesn't need to be clean coming into the pedal and gives you more flexibility in the signal chain.
