Where does this wire go?
Discussion in 'Tele-Technical' started by Flying Teapot, Nov 12, 2019.
  1. Flying Teapot
    Flying Teapot TDPRI Member
    Derby, England.
    This is probably a very silly question but what should this loose wire be attached to in the bridge pickup? CBC35F38-4C50-4C1E-92BB-CCC863625D21.jpeg
  2. phil fridge
    phil fridge TDPRI Member
    At a guess, an additional earth under the bridge plate...though the wire looks too thick to sit comfortably under there
  3. Zepfan
    Horn Lake, MS
    Bridge pickup base plate ground?
    boris bubbanov likes this.
  4. Flying Teapot
    Derby, England.
    Thanks, that’s the conclusion I came to. It just squeezes in the very edge of the cavity.
  5. old wrench
    old wrench Tele-Afflicted
    corner of walk and don't walk
    It looks like you've already got a cavity ground.
    I think that ground terminal slips over one of the bridge pickup mounting screws.
    g
    howardlo, boris bubbanov and sjtalon like this.
  6. mfguitar
    mfguitar Tele-Afflicted Silver Supporter
    Buffalo
    I would trace it but it may connect to the cavity ground screw as well.
  7. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    BINGO
    jvin248 and old wrench like this.
  8. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    Yep, goes between the bridge plate and the silicone rubber tube.
    howardlo likes this.
  9. Vizcaster
    Glen Head, NY
    The lug screwed to the bottom of the cavity is meant to provide a ground connection for the conductive paint so it operates as shielding (and the blob of solder down there looks suspiciously round as if the metal under it was not hot enough for the solder to flow out).
    As Tuxedo demonstrates for you, the other lug that you picture being free is meant to be installed so that it is touching the bridge plate. Some Teles just have a piece of wire smashed down between the plate and the paint. This provides a connection to ground for the bridge plate, and the saddles, and the strings. This "string ground" helps to quiet some noise (ever notice a sound when you take your hands off the strings?).
    Just a fine point, but Tux's drawing shows something that your pickup probably does not have, that is, a jumper between the black wire eyelet and the back of the pickup. You'd only have that if you had a metal base plate on the pickup. In that case, the little jumper means the black wire to the pickup is also jumpered to the base plate. And pickups with a metal base plate provide an alternate way to make a connection to the bridge plate because the mounting screws touch both the bridge plate and the pickup backing plate.
  10. JIMMY JAZZMAN
    JIMMY JAZZMAN Tele-Meister
    Baltimore
  11. boris bubbanov
    New Orleans, LA + in the
    It does NOT go between the bridge plate and the body. It goes to ground via the pickup fasteners. I see them on guitars with bridge pickups with no base plate, in stock form.
    Don't put this between the bridge plate and the plane of the body, because if you do the plate cannot lie flat and you could get microphonic squeal.
