Where do you set your action?
Discussion in 'Tele-Technical' started by Marc Morfei, May 6, 2021.
  1. Marc Morfei
    Marc Morfei Friend of Leo's Silver Supporter
    Wilmington, DE
    For those of you who keep track of such things, where do you like to set your action? I used to think 6/64ths was fine, but as my playing has improved that has become too high. 5 is ok, 4/64ths seems just right. But I am having a hard time getting there without sacrificing tone. With all my guitars, I find that once I nudge it lower than 5/64th I get a faint buzz and the strings take on an unpleasant kind of thin or tinny quality. Sometimes I can't seem to even get to 5 without this happening. I have tried messing with the truss rod (a little relief like Fender says, or pretty straight like other people say) and it doesn't seem to make any difference.
    So my question is: is this normal and inevitable? I am doing something wrong? Should I just be happy with 5 or 6/64th and leave it alone? Are my ears broken?
  2. Freeman Keller
    My starting point for most players and most guitars is
    - structurally sound
    - perfect frets
    - relief 0.003 - 0.004
    - first fret 0.014 (high E) to 0.018 (low E)
    - 12th fret 0.060 (high E) to 0.090 (low E)
    - pickup height as required to balance
    - intonation +/- 2 cents
    That is a good "medium low" starting point for both electric and acoustic guitars. I'll modify it to suit the player (and guitar) as required. Here is a little more detail
    https://www.tdpri.com/threads/basic-setup.952636/
    Oh, and I keep track of these things. I fill out a spreadsheet on every guitar I work on with the starting measurements, my targets and the final ones.
  3. J. Bonkosky
    J. Bonkosky Tele-Holic Silver Supporter
    Seattle Washington
    Factory specs to start. Then I see how low I can go.
  4. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    In the spare bedroom, on my workbench.
    I’ll see myself out…
    Fendereedo, pippoman, ynoT and 27 others like this.
  5. Chupacabra
    Chupacabra Tele-Meister
    massachusetts
    Somewhere below the belly button.
    +/- 1/64th of course.
    bluesguy62 and Siegeld like this.
  6. schmee
    15th fret:
    Probably about .070/.080 on the high E
    Maybe .125 on the low E. I like the low E high to avoid rattling on that boogie stuff.
    I rarely find I like it lower. Cleaner more distinct notes with it up a bit.
    JIMMY JAZZMAN, Viejo and bluesguy62 like this.
  7. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    I have no problem with 5/64 on bass and 3/64 on treble side. I like to heavy hand my strings sometimes, and going any lower is a recipe for buzz.
    Maguchi, Zappastectomy and bluesguy62 like this.
  8. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    The title says "set", not "get".
  9. Dan German
    They say there’s always that one guy, but apparently there’s also always that one other guy… :D
  10. Fuelish
    Fuelish Tele-Holic
    foothills of the Great Smoky Mountains, east TN
    Have never, in 50+ years, ever measured, honestly.... I just lower or raise it until it’s comfortable on that particular guitar... I have a couple low, a couple higher, a couple in between.... whatever works and feels good
    Maguchi, turfdoc, RhinoV and 13 others like this.
  11. beagle
    beagle Friend of Leo's
    Yorkshire
    I usually adjust mine while sitting on my couch and reading the forum, I never measure anything, the guitar tells me what it needs...
  12. Dostradamas
    Dostradamas Tele-Meister
    Oregon
    I drop the saddles til they touch frets then individually raise til they sound right.
    As low as I can without twang/buzz/yuk
    Mugs, bluesguy62, adjason and 2 others like this.
  13. Kevin Wolfe
    Kevin Wolfe Tele-Holic
    Lakeland FL
    Kitchen table. No air conditioning in my shop.
    pippoman and bluesguy62 like this.
  14. JL_LI
    JL_LI Poster Extraordinaire
    Long Island, NY
    I don’t measure action. It differs a bit between the wound and unwound strings. I set action at the bridge so I don’t get fret buzz on any string from the frets I use from 15 to 22. I adjust the truss rod to give a playing card of relief at 12. I then play, listening for buzz and unintentional string muting from 1 to 7 and checking for feel. If the action feels high, I lower the saddles or bridge. Until it feels right without buzzing. I then tweak the truss rod if need be. I don’t play with a feeler gauge or a caliper. The numbers are a curiosity more than anything else. I play using my fingers and my fingers tell me all I need to know.
    RhinoV, bluesguy62 and watercaster like this.
  15. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    For me, each string needs to speak clearly on every fret, whatever it takes.
  16. LutherBurger
    NYC
    5/64" for each string.
  17. memorex
    memorex Friend of Leo's
    Sweet Lorain, OH
    I don't measure the height. I set it where it feels good. If the high E string frets out around the 13th or 14th fret when I bend a whole step up, then I raise it a little, and reset all the other saddles to match.
    RhinoV and bluesguy62 like this.
  18. srblue5
    srblue5 Tele-Holic
    Alberta
    Like yourself, I used to use a higher action -- generally about 6-7/64" -- but since I've stopped playing live and spent more time working on my technique in the past year, I've found that it's too high that way. Gradually, I've been having the action on my electric guitars lowered to 5/64". I find that it's low enough for comfort but high enough to facilitate bends and occasional slide playing and to minimize most (but not all) buzzing. I've had my acoustics adjusted to about 6/64" but don't necessarily love the buzzing that comes with it...I may go back to 7/64" there, but we'll see.
    bluesguy62 likes this.
  19. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I would guess out of 20 or so guitars, two would be similar. Typically a tad above buzzing. I have never measured. I eyeball the relief and nut height as well. Yonder lies the sinner...
    bluesguy62 and Dan German like this.
  20. lmjmitchell
    lmjmitchell Tele-Meister
    NC
    I start with the factory specs, then see if I can get away with lowering it more without any buzzing.
