Where do you get these?
Discussion in 'Amp Tech Center' started by matt117, Feb 2, 2018.
  1. matt117
    matt117 Tele-Holic
    Manitoba
    Vibration isolation shock mounts? Or what do you call em?
    Two of these keep each tube socket on my 65amps London Pro from being mounted directly to the chassis.
    While replacing v2s 12ax7 this guy gave in before the tube got into the socket.
    One leg goes through a hole in the chassis,the other mounts the socket between it and a nut
    Check McMaster Carr. No luck.
    Any amp kit suppliers have these?
    Thanks
  2. tubejockey
    tubejockey Tele-Meister
    the bozone
    You could always mount the socket with a long screw, rubber grommet and fiber-lock nut.
  3. matt117
    matt117 Tele-Holic
    Manitoba
    True... hadn’t thought of that.
    Just kinda want the real deal part tho. But that’s a good option for the time being.
