Where do I put my ground wire?
Discussion in 'Tele-Technical' started by django73, Aug 13, 2012.
  1. django73
    django73 TDPRI Member
    denmark
    Hi people
    I have some noise problems on my tele.
    There are some hizzle noise when connected to the amp. Its not something that affect the sound very much, and it isnt louder than the tones, but you can hear it (its worst when not playing :lol:). When I take my hands of, and dont touch any parts on the guitar, the noise gets much louder. It normaly does on all guitars, but this is much louder.
    Could it be a wire ground problem?
    Ive checked the electronic, and by looking at this diagram, I can see that I dont have that ground wire at my pot:
    https://sites.google.com/site/phostenixwiringdiagrams/teles/2-pickup-teles#StandardTele
    If I connect a ground wire to the pot, where do the other end go to.......?? The bridge?
    All the best
    Kent, Denmark
  2. LarsOS
    LarsOS Tele-Holic
    Norway
    The backs of both pots should be grounded, as well as the bridge plate, and the neck pickup shield. When it comes to grounding, it doesn't matter much what you connect to what, as long as everything is connected to everything. :)
  3. django73
    denmark
    Ok, what about the ground wire on the diagram? Is that a dead end?
    I dont have a ground wire on my pot, does it matter?
    Everything else is wired as on the diagram
    Kent
  4. trev333
    Coolum Beach,Australia
    Some people poke that spare earth wire back into the bridge PU cavity... strip back the insulation a few cms .. unscrew your bridge plate a bit and fan the bare end of the earth wire and push it between the underside of the bridge plate and the body so it sits flat as you can get it then screw the bridge back down clamping it against the body for an added earth point...
    usually the metal of the bridge is earthed back through the pickup mount screws and earthed through the base of the PU... black wire...
    just an extra thing some people do.. it shouldn't be a necessity... tape the end off and let it float in the control cavity is OK...
  5. PinewoodRo
    PinewoodRo Tele-Afflicted
    Carmarthenshire, Wales.
    On a Tele, the pots can be grounded by connection to the metal control plate. As long as one of the pots or the switch has a wire to the output ground you should be ok. (But not always, you should check with a multi-meter).
    jlem3 likes this.
  6. NastyMojo
    NastyMojo Tele-Afflicted
    TOC,NM
    I just wrap it around a screw and screw the screw into the woods.....gets the job done...
    jlem3 likes this.
  7. django73
    denmark
    Thanks for your replies.
    Ive tried the things you wrote, but it doesnt seem to reduce the noice........I know there is noice when you dont touch the hardware, and it goes away when you put your hands back on. My tele just have a bit more noise than my other guitars, and its a bit to much..........any suggestions to get that solved...........
    Thanks
    Kent
  8. krasy
    krasy TDPRI Member
    Bulgaria
  9. django73
    denmark
    It dosnt make any difference, connecting the wire under the bridge.......?!?
  10. Thinlineggman
    Thinlineggman Tele-Afflicted
    Oregon City, OR
    When I get too lazy to drill a hole, I just run a piece of shielding tape from the control cavity to the bridge.
    Edit: Single coil pickups are by nature noisier than humbuckers or noise canceling pickups. So unless you have humbuckers or noise canceling pickups, you will have a little bit of buzzing. Just the nature of the beast
  11. surfco
    surfco Tele-Afflicted
    BAJA
    Can I use the control plate of the Telecaster to wire grounds???
  12. musicalmartin
    musicalmartin Poster Extraordinaire
    Norfolk UK
    Simple way to check if bridge needs grounding is to just touch a wire to bridge and control plate .If the noise stops then ground bridge .
  13. Thinlineggman
    Oregon City, OR
    On that bass I posted I didn't wire any grounds because the plate grounded everything. And the strip to the bridge grounded everything to the strings.
    I'm still gonna wire grounds to everything, just to be thorough, though.
  14. LarsOS
    LarsOS Tele-Holic
    Norway
    :eek:
    And here I thought I was an expert on lazy. Let's just say you just put me in my place. :D
  15. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    I rewire all Tele pups with two coil wires and a separate ground wire like the stock Fender Texas Specials and use copper foil screening in pup and control plate cavities.
    Neck is coil start and finish + separate ground to cover and bridge is coil start and finish + separate plate ground which also grounds the bridge through the pup mounting screws. Seems to work.
    I wish all the manufacturers did it this way as it makes life that much easier for 4 way and reverse switching.
    Chrome control plates are excellent conductors and the bridging wires between pots are unnecessary unlike Strat wiring.
  16. Thinlineggman
    Oregon City, OR
    I do what I can :D
    I didn't have a drill bit long enough and didn't want to go buy one, so yeah haha. Now the finish has faded around that strip, so it looks weird if it's not there....
  17. jlem3
    jlem3 TDPRI Member
    Fort Edward NY
    Thanks, I tried something around the lines of that... Im still missing something somewhere...IDK , back to it I guess
  18. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    No, do not do this.
  19. Telecentric
    Boulder Creek, Ca
    Absolutely. This is how my Tele is wired. Nothing soldered to pot shells. Dead quiet.
