When reverb tanks die...
Discussion in 'Amp Tech Center' started by charlie chitlin, Dec 14, 2018.
  1. charlie chitlin
    Kimberton
    ...what happens to them?
    '68 Pro Reverb with the original Accutronics tank and very weak 'verb.
    When I try the tank from a DR, it sounds great, so it's the tank.
    It sure LOOKS like every working tank I've seen the insides of.
    Springs connected, wires connected...
  2. mally
    mally Tele-Holic
    runcorn cheshire uk
    **** happens ! But at least they are cheap
    soulman969 and uriah1 like this.
  3. mally
    mally Tele-Holic
    runcorn cheshire uk
  4. flyswatter
    flyswatter Friend of Leo's
    One thing that can go is the transducer at either end of the tank (one for input, one for output). They have tiny little coils in them that can break or fail over time. I've repaired tanks by grafting in a new transducer from another old tank, but it's a finicky process.
    Wally likes this.
  5. JMac52
    JMac52 Tele-Meister
    Mesa, AZ
    I had one that made an awful kerrang noise only on certain notes. Couldn’t see anything wrong with it either.
  6. jrblue
    jrblue Friend of Leo's
    Santa Barbara
    I assume you have checked all the connections and that you're not just losing signal. It's probably the transducer.
  7. Wally
    Charlie, a multimeter will tell you if a transducer ...or a connection to a transducer...is bad.
    charlie chitlin and corliss1 like this.
  8. printer2
    They go to reverb tank heaven?
    BobbyZ likes this.
  9. tubejockey
    tubejockey Tele-Holic
    the bozone
    or somebody replaced it with the wrong tank. You can sometimes get more performance from a tank by eliminating the slop from the transducers with a drop of epoxy. Put a drop on the spring connections as well.
    robrob likes this.
  10. bcorig
    bcorig Friend of Leo's Silver Supporter
    In the 909
    Only the good ones go back to Corona.
  11. Bendyha
    Bendyha Friend of Leo's Silver Supporter
    Northern Germany
    Virtuous ones are boing again.
    teletimetx, rob2, robrob and 4 others like this.
  12. jackal
    jackal Friend of Leo's Gold Supporter
    mojave desert
    I always just replace the with a MOD tank, always an improvement.
  13. ScottJPatrick
    ScottJPatrick Friend of Leo's
    Stirling, Scotland.
    And they say Germans don't have a sense of humour, very subtle bendyha, thought you were nearly going down this line for a second, https://bjornagain.com/ Now I wonder if Abba originally got their name from an Accutronics reverb tank code.......
    Bendyha and bwacke like this.
  14. bwacke
    bwacke Tele-Meister Gold Supporter
    Toledo, OH
    Years of bouncing around during transport stretches the springs and they lose their structural resilience. The stretchy springs elongate and attenuate the desired signal. They'll sometimes be sloppy enough to drop to the floor of their mounting area in the cabinet or bag and become a seismometer that thunders with every step a nearby band member makes on the stage. If you're very careful, it's possible to clip a turn out of the springs and bend a new hook to tighten them up. But that operation is delicate and risky.
  15. jman72
    jman72 Tele-Afflicted
    Central Florida
    I have a similar tank from a 70s Pro Reverb that seems to be intact (and the transducers seem to measure ok with my multimeter), but the reverb is very weak (even on 10 it sounds like a 2 or 3). I switched out the tank from a SFTR, and it works great, so I know it's the tank, but there is nothing obviously wrong with it. I guess I'll just buy a replacement.
  16. Bob Womack
    Bob Womack Tele-Afflicted
    Between Clever and Stupid
    I've heard that the sound is something like what you hear When Doves Cry.
    Bob
  17. wanderin kind
    wanderin kind Tele-Meister
    Olympia WA
    usually the coil in the pickup transducer,
    too cheap for a new tank even at $18.95?
    vegan glutton free type who hates landfill?
    drill out rivets, un lace core, careful not to bend the nickel lams as they lose permeabillity (so you lose signal)
    slide coil off by bending lams (wait, didn't you just tell me...), unwind coil, find a used pickup with an open coil, lay pickup on the ground, put bobbin in a 1/8" drill bit, hook to drill, wind as much #44 as will go on there, s/b over 2000 turns but how would you know?
    re-install coil, solder leads, play some dick dale music, repeat as needed,
    oh and good luck with those tiny magnets on the piano wire,
  18. uriah1
    Around
    Repair is pain in butt. Been there..
    Get new
    Bill Moore likes this.
  19. TeleDrifter
    TeleDrifter Tele-Afflicted
    Phoenix, AZ, USA
    I have a accutronics 9 1/2 inch 3 spring reverb tank. I get 60ohms on the input side & 207ohms on the output side. Are these normal readings for a functioning reverb tank? The red lead from the amp read 5ohms, the black lead reads 20ohms. I'm not sure which is for the out & which is for the in. This is for a Fender M-80 head. Is there a way to check the signal coming from the amp?
  20. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    Red usually is input for Fender.
    Accutronics has a chart online to find impedance with resistance measurement.
