MichaelWhy
Hi All
I have a bunch of old EF80’s that a got for use in robrobs micro designs. I have a little sencore tc109 tester but that just gives a bad to good scale. The EF80’s are all in the good range some only just but had one that didn’t work in an amp, so I just marked it and put it to one side.
I decided to build a tester that would give something more that degrees of good/bad. it supplies the plate and grid with voltages from the tube data sheet and gives the plate current as a ma measurement
I have tested a bunch of preamp and power tubes and am getting readings close to manufactures specs so presume it’s working as intended.
so from looking at the data sheet for the EF80 the plate current should be 10ma and the 10 or so I tested range from 6 to 11ma. the one that didn’t work measured at 3.5ma
what is the plate current telling me , if it’s supposed to be 10 ma but if these are used in the power section would the one that measured 11ma give 10% more power and same for 9 ma would that be 10% less power similarly if it was a preamp tube would that be +/- 10% gain so a good 12ay7 could have the same gain as a weak 12ax7 Or does it not work that way.
1.At what point is a tube considered bad, is there a +/- tolerance
2.what happens if I use one that measures 8ma so the amp works but it’s way off spec
3.are there any other measurements I need to determine how good or bad a tube is
4. is tube matching using a pair or quad of tubes all with similar plate current measurements or a different measurement
5. what +/- is considered a match , I.e. is 9 and 8 ma a match or 8.3 and 8.4
sorry for all the questions I have not been able to find a good/easy to understand write up of what tube parameters are important
