LostTheTone
In theory most people could survive with one amp, but they would need some sort of cobbled together solution to really be useful both at gigs and at home.
We all know amps and speakers behave differently at different volumes. We all know that practically every overdrive sounds worse through headphones without some additional special sauce.
So, with that in mind, it's pretty obvious why people end up with two amps. Because what sounds bad ass blasting through 4x12s is likely to sound pretty meh when you're trying not to wake the kids.
Now, I'm not saying whether people spend their money in the right ratio, but as a real human being I completely understand it.
To put the question slightly differently - Why have a good, physical amp and also have a desktop software amp/effect sim? In theory you could use one for both uses. In theory. But you wouldn't want to.
For stage work, a physical amp is vastly more reliable and much less delicate. For home recording work, software is great both for headphones but also to give you access to more tones and sounds and effects. If you need a Vox or Fender sound but you only own a Marshall, or whatever, then no problem. On stage people don't mind so much about those intricacies, but to record you want it just so, and saving settings so you can come back and play again in months time no matter what else you did in between is great.
There are reasons here.
