When amps have mic inputs...
Discussion in 'Amp Tech Center' started by schmee, May 30, 2019.
  1. schmee
    I wonder what the input difference is? A harp playing friend has asked me to look at a SS guitar amp he uses that feeds back too much. Wondering if there's something simple I might do to tame the input better for a crude mic those guys use...
  2. Rockdog
    Rockdog Tele-Afflicted
    Heart of the Commonwealth
    Just a thought and maybe worth a try...
    My old Bandit as a High and Low input. When you put a plug in both, the output defaults to Low. A dummy plug in the instrument input may attenuate the mic input.
    JL_LI and schmee like this.
  3. kennl
    kennl Tele-Afflicted
    Moon Township, PA
    Suggest a different harp mic.
    Green Bullets feed back less than those Astatic mics, which behave like a microphonic Tele bridge pickup.
    nojazzhere and Old Deaf Roadie like this.
  4. Bill Moore
    Bill Moore Tele-Afflicted
    Silver City, New Mexico
    I have been thinking of building a harp amp for my brother in law, and thought I might use a 600 to 10K ohm matching transformer on one input. (With an XLR).
  5. schmee
    He's using a Bullet. But I'm not sure he's just gotta learn some more tweaks, I sold him a SF Champ a while back and he "cant get it loud enough without feedback" he says.
  6. Dacious
    Dacious Doctor of Teleocity
    Godzone
    Drop input gain if you can. I've built a couple of 5E3 and with a 12AY7 in the first slot they work very well with a cardioid mic.
    You can well and truly use a mic in one input and guitar in the other. Even when the guitar is starting to break up the mic sounds clear. Would be giggable with a quiet drummer and doghouse bass.
  7. Milspec
    Milspec Poster Extraordinaire
    Nebraska
    My old '49 Epiphone Century has 3 inputs (instrument, phono, mic). How that works in the circuit is outside of my depth to explain.
  8. schmee
    I need to get him over here and see what he's doing. He should be using input 2 I imagine.
  9. printer2
  10. philosofriend
    philosofriend Tele-Holic
    Kalamazoo
    Look at where he is standing. Right in front of the amp is not good. If the amp is open backed, right behind it can be bad also. Get the mike away from the amp.
    Does he know how to experiment with the tone controls?
    Some amps with two inputs have different tones between the two, one might have less feedback problems. But don't count on it.
    If you adjust the mike by itself so it is right on the edge of feedback, it will squeal when the players hand are cupped around it.
    Rich724, W.L.Weller and nojazzhere like this.
  11. Chunkocaster
    In space with Ziggy
    Make him a copper shielded fedora?
    MrClint, TeleTucson and BigDaddyLH like this.
  12. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Silver Supporter
    Oregon Coast
    Might I suggest a graphic EQ pedal (or rack unit) between the mic & the amp to control the offending frequencies?
  13. schmee
    You know, that's a good idea, I have one he can try.
    Old Deaf Roadie likes this.
  14. magicfingers99
    magicfingers99 Friend of Leo's
    atlanta
    put a mixer in front of the amp so you can eq it.
    65$ on amazon
    they make smaller ones but this is good if he want to loop an fx pedal like reverb into his signal. can also record his sound so he has a mix of his performance using the appropriate routing to a recording device like an iphone or mp3 player etc.
  15. KyAnne
    KyAnne Tele-Afflicted
    Swamps of Louisiana
    Instrument, old phono, and mic in 1949? Probably not a nickels worth of difference (impedance wise) in any of 'em.
    magicfingers99 and Bill Moore like this.
  16. Milspec
    Nebraska
    I suspect not
  17. FenderLover
    Minnesota
    Maybe check out the Weber 5F2H Harp amp for ideas:
    https://www.tedweber.com/media/kits/5f2h_schem.jpg
    They use local NFB on the first stage. That will decrease gain and input impedance.
    robrob likes this.
  18. 24 track
    24 track Doctor of Teleocity Ad Free Member
    kamloops bc
    I have a pair of these ( one of each) they are inexpensive used (20.00 for the one with out the meter , and 25.00 for the one with) I replaced the 12 AX7 immediately with something of better quaulity and these work great , they also work as great tube powered DI's
    FenderLover likes this.
  19. kbold
    kbold Friend of Leo's
    The phase reversal switch will do the trick.
    24 track likes this.
  20. Paul in Colorado
    R.I.P. 2019
    Get him a longer mic cable.
    But seriously, I believe the mic inputs were padded down a bit. I should ask a guy I know who works on old amps and especially likes ones from the '40's.
    I will report back!
