Probably because of my post. I was just stating that I used an SD-1 to boost a BD-2 for a number of years in my rig. The BD-2 at low gain settings gets you into edge of breakup Fender territory. An SD-1 or a TS stacks nicely into it, and it gets you a solid boosted mid drive tone into a clean amp.
That's exactly as I was saying in my earlier post: these pedals work great in their intended application, which is NOT to be a substitute for a crunch channel...a.k.a. an "always on" pedal.This is where the misunderstanding of a Tube Screamer is....
It wasn't designed to be used as dirt into a clean amp - IMO, it sounds terrible as a "primary" dirt pedal. It was designed to put in front of a dirty amp... to hit that amp harder for leads. When doing so it emphasized the mids (by rolling off highs and lows) and leads would jump out and sound thick.
Don't use a Tube Screamer as part of you core dirt tone, use a Tube Screamer to Boost/Goose that core dirt tone. IE: Put it in front of a dirty amp or another (already on) dirt pedal. That's when the magic happens.
This is how I use my Joyo TS clone now ( when I use it at all) as an occasional
lead boost to my Blues Driver which is always ON.
A BD-2 replaced a TS for me many years ago, and most of the time, that's all I need.
( if I'm doing a harder-rock gig than my usual, I add in the Joyo TS or a Rat clone, if I want real distortion )
I think I'd use different wording, and say this is where the limitation of a stock Tube Screamer is.This is where the misunderstanding of a Tube Screamer is....
Wampler Moxie and the Mini-TS. Had an SD-1 years ago, never got into it. All around the tube screamer had a better sound than the SD-1. The OD-3 and BD-2 sounded decent but never earned a spot on my boards. The OD-3 sounded a bit too "farty" with it's strange bass frequency, the higher you set the gain, the more apparent it is.I was a big Tube Screamer fan for most of my tears if playing but picked up a Biss SD1 super overdrive about 5 years ago on a whim because it was on sale. I've been a fan every since. To my ears it just sounds more harmonically alive, possibly due to it having asymmetrical clipping and the TS9 is symmetrical. It also sounds good ran into a clean amp where the screamer really only likes dirty amps.
What's your favorite of the 2 and why?
It rolls off so much treble and bass that you basically need the amp to do the heavy lifting for you.
Oh I know that and I use my SD-1 in the same fashion. I just mean that as a standalone OD for a bit of grit, the SD-1 is my choice over the TS.This is where the misunderstanding of a Tube Screamer is....
OD-3 with less bass would be awesome...I wonder if there's a pedal out there that is basically that?Wampler Moxie and the Mini-TS. Had an SD-1 years ago, never got into it. All around the tube screamer had a better sound than the SD-1. The OD-3 and BD-2 sounded decent but never earned a spot on my boards. The OD-3 sounded a bit too "farty" with it's strange bass frequency, the higher you set the gain, the more apparent it is.
If the tube screamer sounds bad/icky or seems unusable, the user probably isn't using it right. Maybe they don't know how to EQ their amp or are using the pedal in some way the pedal isn't supposed to be used.
This.This is where the misunderstanding of a Tube Screamer is....
