Whats your favorite electronic cleaner
Discussion in 'Amp Tech Center' started by jimbo735, Jul 13, 2013.
  1. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    I'm going to do some maintenance on my amps and guitars whats your favorite electronic contact cleaner. And yes I am am aware of high voltages and know how to drain the life out of my amp:)
    I have used crc before but was wondering about some of the other brands,if you think there any better please tell me your experience.Thanks
  2. max_twang
    max_twang Tele-Afflicted
    New York
    I think that Caig De-Oxit is supposed to be good stuff.
  3. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    De-Oxit is the best, but I use alot of Radio Shack also just because I can go get it if I run out.
    Know the difference between the Cleaner and the Cleaner/Lubricant, and know where to use or not use each of them.
  4. alnicopu
    alnicopu Friend of Leo's
    The city
    We used to use Deoxit back in the day at Xerox before the EPA banned the original formula. All of a sudden we were able to order it again but got questioned if we ordered it too frequently. Turns out they found a loophole by getting it through XCI (Xerox Canada). Come to find out it was $70.00 for a little squeeze bottle with a needle on top to apply it, was a little thicker than machine oil and left a film. You could put a drop on green, corroded pins and the corrosion wiped right off with a Q-tip. We would also use it on push on shielded comm. lines and all your connection/corrosion problems disappeared. I stashed away a couple of bottles before I left and they lasted me about 10 years. The stuff was a forever fix back then.
  5. Harleyjon
    Harleyjon TDPRI Member
    England, UK
    Change the pots, don't be lazy, it won't let you down. Most cleaners are corrosive and rot plastics. Use with caution!
  6. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    After decades of using just about every cleaner out there, I always thought of them as a quick, sleazy fix that didn't last. DeOxit, on the other hand changed that opinion. Provided that your parts aren't simply worn out, DeOxit does work very well.
  7. jimbo735
    Michigan
    Thank you gentleman I have four pots that a candidates for new and I think the rest are just needing a bath.But will see after there clean.
  8. alnicopu
    The city
    I agree with HarleyJon. Most anything needing cleaning with a cleaner other than blasting out sockets, are too cheap not to just replace and be done with it. Its usually temporary at best. Just keep the old ones for the collector crowd. If I bought a 641/2 mustang I wouldn't expect to get the original points, plugs or tires.
  9. steveneddy
    steveneddy Tele-Meister
    DeOxit for the pots and tube sockets - and I never clean power switches - only replace when faulty.
    I like to clean PCB's and hand wired boards and connections with regular acetone to get rid of the solder flux - but be careful as some boards will be damaged by acetone.
    I like to put a little DeOxit in the tube sockets on new amp builds and when replacing old tubes as it keeps the connection good and clean over time.
  10. jimbo735
    Michigan
    This is all good solid information to abide by.
    Thank you.
  11. Radspin
    Radspin Friend of Leo's
    Long Island, NY
    DeOxit. The stuff is amazing.
  12. bblumentritt
    bblumentritt Tele-Afflicted Platinum Supporter
    Austin, Texas
    Another vote for DeOxit.
  13. Lunchie
    Lunchie Poster Extraordinaire
    Downstate Illinois
    I use CRC, mostly because its the only thing I can get in town.
  14. limbe
    limbe Tele-Afflicted
    Stockholm,Sweden
    Among the best stuff I can get is Super Servisol 10. Switch cleaning lubricant.
    Haven´t found any plastic that is sensitive to it.
  15. 6942
    6942 Poster Extraordinaire
    Santa Fe, NM
    De-Oxit....although we used CRC on the RR by the truckload.
