What's wrong with this AC30? Weird octave noise
Discussion in 'Amp Tech Center' started by pinkpanda, Jul 12, 2020.
  1. pinkpanda
    pinkpanda TDPRI Member
    Utrecht, Netherlands
    Just bought the amp yesterday. With certain notes there’s some extra low octave noise. Both in normal and top boost channel. Seems to be really prevalent on an Ab. I changed guitars, but still the same.
    Anyone has some ideas on what it might be?
  2. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. UK.
    I would replace the EL84s firstly as if the screen grids have loosened over time, they do vibrate and produce an overtone like yours.
    Tapping the valves lightly, with a chop stick or Biro one at a time, should pin point the faulty valve.
  3. Dacious
    Dacious Poster Extraordinaire
    Godzone
    I had a 6L6 in an Electar Tube 10 with a loose element - it would produce almost exactly that tone on low As. Jon's likely right, you have a loose bit in a tube.
  4. Javier668
    Javier668 Tele-Meister
    Angol Chile South America
    Your caps are ok?
    My champ silverface when failed played ghost notes.
  5. pinkpanda
    I'm gonna check the tubes this afternoon. Because it's most obvious at a G/Ab, it can be a 100Hz hum. Buddy of mine suggested the caps as well so gonna check that after a tube check
    Wally likes this.
  6. schmee
    schmee Doctor of Teleocity
    "Follower" notes are often a result of bad filter caps. If it's buzzing a speaker voice coil rub.
    But yeah, could be a harmonic tube, although that's usually a higher harmonic than a low one.
    Wally likes this.
  7. jrblue
    jrblue Friend of Leo's
    Santa Barbara
    I'm assuming from the general direction of the posts that this is a used amp. If new, I'd bring it back rather than troubleshooting it, if used, you've been given good advice as to where to start. Those added undertones can be maddening! Let's hope it's just an ailing tube.
  8. Doctorx33
    Doctorx33 Tele-Afflicted
    Atlanta
    If your AC30 is a Custom Classic, don’t use the standby. Leave it on all the time.
    Mad Kiwi likes this.
  9. pinkpanda
    Thanks everyone for the input! It's an AC30C2 and the reverb tank is dated 2014, so the amp isn't too old. I am in touch with the seller. He wasn't aware of the problem, which I believe. I just checked the tubes, and they look fine. No ringing or anything.
    It's probably an issue with the filter caps, because it really sounds like 'follower notes'. I hope I can get my friend to help me check it out, he often repairs electronic gear, so I have the idea he might be able to help me get it fixed.
  10. pinkpanda
    So checked the tubes. V1 was a bit microphonic but changing didn't resolve the issue. Power tubes were no real issues with either. There's no real 100hz hum or noise and the problem disappears when putting the amp on its front or side. Very peculiar, looks like a mechanical problem and don't expect this will be a real easy fix for myself.
    Anyone else ever experienced an AC30C2 with ringmod feature?
  11. allesz
    allesz Tele-Holic
    Italy - Bologna
    From the phone's speaker It does not sounds that bad.
    Did you try tightening all the screws in the cabinet, speakers bolts etc?
    pinkpanda likes this.
  12. milocj
    milocj Friend of Leo's
    Michigan
    I know it can be a bit of a pain to access the tubes on some AC30s, but try cleaning all of the tube pins. A spray of good contact cleaner like DeOxit on the pins and then removing and replacing each tube a couple of times should do a decent job of cleaning any layer of corrosion off of the pins or tube sockets.
    I've had this happen a few times and it's usually right around that Ab and A area on the two lowest strings.
  13. tap4154
    tap4154 Doctor of Teleocity Ad Free Member
    Southern California
    Also double-check that something hanging on your wall or a bookcase or something isn't ringing in sympathy. I have a bookcase near my amps and some of the shelves that didn't have anything on them were lightly vibrating against the back of the bookcase. Made a similar noise.
    Mad Kiwi and pinkpanda like this.
  14. pinkpanda
    Haven't, but everything looks really tight. Doesn't sound like rattling bolts to me, but will check them when I have the amp open again.
    Think I'll try this. I don't have DeOxit in home, but do have some Contact Cleaner 601. If that doesn't work, I probably would have to replace tubes I think.
  15. pinkpanda
    OMG, this did the trick. Weird noise is gone! I scraped a bit very carefully of the pins sides. Next, I put some contact cleaner and brushed it with a toothbrush. Put it in and out a couple of times and worked great!
    Only problem now: the top boost channel is not working anymore. Probably one of the tubes I've worked on, but I only worked on the power tubes. Anyone knows which one is the tube for the top boost channel?
  16. Jon Snell
    Jurassic Coast. UK.
    "Only problem now: the top boost channel is not working anymore. Probably one of the tubes I've worked on, but I only worked on the power tubes. Anyone knows which one is the tube for the top boost channel?"
    The model is AC30/?
  17. pinkpanda
    AC30C2
  18. Jon Snell
    Jurassic Coast. UK.
    Screenshot 2020-07-20 at 12.52.10.png VR2 is the TB volume, V1 is the first stage and V2 does the business. Check the valves are seated correctly first and then check the valve voltages.
  19. pinkpanda
    Thnx. Swapped V2, did nothing. Swapped V1, did the trick! I think that still the EL84s could use a replacement, but now I know exactly where the problems are of the amp. Thanks all!
    gregulator450 likes this.
  20. Jon Snell
    Jurassic Coast. UK.
    Pleased to help.
