Sea Devil
I've seen Schecter catalogs going back their second or third year in business, at which point their various necks all had numbers indicating Tele-style, Strat-style, neck wood, fretboard wood, etc. This neck doesn't have any of that, just what you see stamped in the photos. Schecter has undergone many changes in ownership since their early days, and the current version of the company tells me, "Our records don't go back that far."
I think it's from their very first year, and may actually be the 99th neck that Schecter ever made, but I have nothing to back that up with. Any thoughts? It's a great neck, but it spent many years with no finish on it and has had some issues with the skunk stripe moving a bit with seasonal changes and truss rod adjustments. I eventually wicked some CA along the edges of the skunk stripe, sanded everything smooth, and finished it with shellac. This may finally have fixed that issue. It's also been refretted; the original frets were pretty wide and so are their replacements - triangular Jescar EVOs, IIRC. The lack of finish was a feature, not a bug, when refretting. Both sides of the neck will always have some embedded dirt, wear, and uneven color, but that's better than removing material unnecessarily. Btw, the small split next to one of the holes seems to have zero effect on mounting stability and shows no signs of creeping. I've also touched up the shellac in the last few days and am delighted with the result.
