musicalmartin
I like my CT0-1.........nuff said.
I just got one of these, and IIRC it doesn't sound like the usual "amp with clipping diodes" harsh overdrive to me. At low gain settings there is a rather subtle and progressive distortion, unlike most overdrive pedals which seem to go straight from silent to full-on buzzy racket. To my ears the timbre of this pedal is also sweeter than Tube Screamers and Muffs and whatnot - it sounds a little more "tubey".The Suhr Riot is NOT a Transparent OD - is a full-on Drive pedal.
However, if you are into this pedal then again, much has been spoken of the copy of this - the JOYO British Sound.
Timmy doesn't = Transparent
Timmy = lots of treble added, as does most "transparent" pedals..
I was trying to use the term "neutrally Eq'd" but i'm not even sure that's truly the case. If something was transparent, then it wouldn't need a tone knob. Or 2.
Sorry this is my current "thing that bugs me" possibly worse than the JRC4558D mojo thing...
to make up for going off on one, guys in the US watch this.
(link removed)
Awesome film
Elsewhere on the 'Net I read that this series of pedals are based on the Tech 21 "Sansamp" products. Those use MOSFET's (in a CMOS op-amp) rather than clipping diodes like most overdrive pedals.
Thanks for all the info on the Angry Troll, 11G. Your knowledge about this stuff is second to none!
11 Gauge, from what I read the Sansamp uses TLC 272 opamps, which I believe are entirely CMOS - Texas Instruments calls it "LinCMOS technology".AFAIK, Tech 21 continues to use "ordinary" op amps in everything. The older stuff used TL072/74 chips, which are just basic jFET-input op amps. Some of the newer character series stuff might be using common bipolar-input op amps like the JRC4580, but I don't recall it being an actual mosFET-input op amp. That is an uncommon chip, and I've only heard of it being used in a few pedals, like the BJFE Honey Bee.
There are CMOS op amps (like the TLC 272), and of course there are those CMOS 4069 and similar hex inverter logic chips.A CMOS chip isn't an op amp - it's a logic "inverter" chip.
I don't know any of this first-hand, only what I've read on the 'Net, so of course it could be wrong. Have you personally taken apart one of the Sansamps and found nothing but TLOxx opamps inside?
Ah - what you probably want is a good Compression Pedal then...
apparently the TLC 272 is a vital part of the sound.
I also hate mangement speak, i think this is the root of my hatred of hype.
Used to have a manager, who would drivel out rubbish like "blue sky thinking", "helicopter view" "actionables" and my personal favourite, which in fact as entered mainstream conciousness as a perfectly acceptable word, "Proactive". mainly because it was used non stop..
ha! gotta love that new "going forward" and "reaching out" crap.
