nnieman
I really like those subtle "bursts"...bravo!
Thanks!
That was my first 2 (successful) bursts
I have a homemade black esquire that has my first burst under the black
Nathan
Two screws on the center line that are independent of the neck mounting screws works just fine.I’m getting ready to finish my first body. What’s the best way to mount a stick to hold it for spraying? Can I drill a couple of extra holes into but not through the neck pocket? Or am I better off using the actual neck mounting holes?
Thanks Jim, much appreciated!Two screws on the center line that are independent of the neck mounting screws works just fine.
Perfection!
Cut the nut slot out and installed the tuners on the baritone neck
I dropped a nut and washer and couldn’t find the washer anywhere in the floor! Looked for 45 mins under everything. Turns out it had bounced into a package of steel wool that has fallen in the floor. I had picked the package up first thing when I started looking but didn’t think to shake it until I was getting desperate!![]()
Working on the final neck fit on the SG.
I've worked it down to very close using the lipstick trick and the fine side of a farriers rasp. Now I'm flossing it in for the final fit.
When you’re getting close to final fit and can’t quite figure out where it’s hitting to keep it from seating perfectly, put lipstick on the tenon where you think the interference is and then set the neck in place carefully. When you remove it, the lipstick will transfer from the high spot to show you where you need more material removed.What's the lipstick trick?? I've had an SG build sitting on a shelf for years bc I got so frustrated trying to make the damn tenon right.
Carbon paper also worksWhen you’re getting close to final fit and can’t quite figure out where it’s hitting to keep it from seating perfectly, put lipstick on the tenon where you think the interference is and then set the neck in place carefully. When you remove it, the lipstick will transfer from the high spot to show you where you need more material removed.
